08-30-2007, 12:42 PM | #1 |
Member#: 128985
Vehicle:2002 bugeye STi-ish MBP |
emissions control+hydra
can the hydra control the "canister purge solenoid valve"?
there is control valve and a vent valve
08-30-2007, 01:04 PM | #2 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
The Hydra uses the "purge control solenoid valve" which vents the charcoal canister at the fuel tank into the intake manifold.
Thanks, Phil www.elementtuning.com |
08-30-2007, 01:06 PM | #3 |
Member#: 135588
Vehicle:2007 STI *SOLD* |
Phil,
We do not have emissions here in North East PA. Now that I have the Hydra what emission valves, canisters, etc.. can be taken off the car? I would like to remove all the extra crap under the hood that I can!! |
08-30-2007, 01:44 PM | #4 | |
Member#: 128985
can you explain a little bit how the hydra controls this? when does the hydra tell it to react? it would be greatly appreciated. |
08-30-2007, 06:00 PM | #5 | |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
offset |
08-30-2007, 06:15 PM | #6 |
Member#: 54918
It opens the solenoid within a certain vacuum range to suck in the fuel vapors from the canister during cruise conditions.
08-31-2007, 02:02 PM | #7 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
I pulled the purge control solenoid out of my car and just left the hardline on the firewall open. I have noticed if I go to the passenger rear of my car, I have a faint gas vapor smell. I don't think it's anything to worry about, but it is there.
02-23-2008, 09:59 PM | #8 |
Member#: 58405
Vehicle:2004 Element GT65'd Hydra, Hydramist'd STi |
hate to bring this back from the dead, but i broke a nipple off on the purge control solenoid valve, do i really need to have one or is there a way to work around it??
I am running a Hydra btw. thanks EDIT: I capped off the hard line under the manifold removed the purge valve and solenoid. The line coming by the firewall is left to vent as of now. The MAP line to Hydra is going to the the little black nipple where the purge valve was connected. Is this right?? Last edited by 48mpg; 02-24-2008 at 07:43 PM. |
02-25-2008, 10:45 AM | #9 | |
Member#: 54918
The vent by the firewall you can leave vented to atmosphere. The hard line attached to the rails that connects the line from the firewall to the purge solenoid valve can be capped off. The large nipple on the front of the intake manifold should be capped off or it can be used for boost gauge etc. The black and tan one-way valve should be removed. The Hydra will now plug directly into the intake manifold The vacuum port on the turbo inlet pipe that used to go to the black and tan one-way valve will be capped off. Thanks, Phil www.elementtuning.com Last edited by Element Tuning; 02-25-2008 at 02:04 PM. Reason: needed to clarify turbo inlet not intake manifold |
02-25-2008, 11:16 AM | #10 |
Member#: 58405
ok, great, i have the Hydra MAP line going to the nipple where the black and tan one-way valve went,
i want to try and find a 90 of that nipple to have that MAP line run nicer, thanks again phil with the quick responses loving the setup, everything seems to be running well so far, now comes the Hydramist install that i'm dreading |
02-25-2008, 12:14 PM | #11 | |
Member#: 135588
P1443 Evaporative emission control system vent control function problem | gtlegg | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 09-21-2009 04:09 PM |
Evaporative emission control system vent control function problem | holtian143 | Newbies & FAQs | 8 | 09-30-2005 11:19 AM |
Evaporative emission control system vent control function problem | holtian143 | Service & Maintenance | 3 | 09-29-2005 06:24 AM |
Check engine code P1443: Evaporative emission control system vent control function? | garface | Normally Aspirated Powertrain | 7 | 11-20-2002 06:53 PM |
Fuel Emission Control TSB | DaveArmitage | Warranty Issues & SOA Problems | 12 | 05-02-2002 09:19 AM |
