Old 08-30-2007, 02:52 PM   #1
breakfasteatre
Member#: 131662
1996 Legacy LS
Default The final word on H6 rear upgrade?
Alright, ive read alot about brake upgrades in the past few weeks. I just want to clarify some things
this is my rear caliper (1996 LS wagon)
the caliper design is a pivot up design, wherein you only have to remove one bolt to change the rear pads
am i correct in stating that this is a different caliper design than the H6 rear calipers? Those calipers are not a pivot design?
So that when i take a trip to the junkyard, that i will need, rear rotors, the caliper bracket, and the calipers and pads?
thank you for your patience
breakfasteatre is offline   Reply With Quote
Old 08-30-2007, 02:56 PM   #2
rougeben83
Member#: 115154
2003 Legacy L Turbo
play it safe and get the caliper along with the bracket. Your current caliper *looks* like it can work with the bracket, but it looks pretty rusty, and odds are the caliper you'll be getting with the H6 will be newer and have less miles on them.
The extra $$ to get the calipers aren't going to be that prohibitively expensive if you go to a junk yard TBH.
Oh yeah, remember to drill out your dustshields cause those won't be able to fit the bigger rotor.
rougeben83 is online now   Reply With Quote
Old 08-30-2007, 03:06 PM   #3
breakfasteatre
Member#: 131662
1996 Legacy LS
Searching through the brake forum found me the answers:
the caliper is the older style caliper, as opposed to the new style needed for the H6 upgrade. I will need the caliper, pads, the bracket and rotors
the rear brakes are looking pretty shabby anyways
Old 08-30-2007, 05:03 PM   #4
rougeben83
Member#: 115154
2003 Legacy L Turbo
oh yeah, remember that autozone now sells the parts for the h6 brake upgrade, so if youre looking for decently priced rotors and preloaded rebuilt calipers, that's the place to go.
Old 08-31-2007, 02:27 PM   #5
that one legacy
Member#: 103665
^ Any idea what the cost is for those parts though?
that one legacy is offline   Reply With Quote
Old 08-31-2007, 03:39 PM   #6
rougeben83
Member#: 115154
2003 Legacy L Turbo
Rotors were $25/ea when I did my brakes a few weeks back...not sure about the calipers though. I don't think they cost more than $70 /caliper TBH.
Old 09-22-2007, 07:33 PM   #7
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Are the brackets available at AutoZone too?
Sneeky Pete is offline   Reply With Quote
Old 09-22-2007, 10:34 PM   #8
that one legacy
Member#: 103665
i highly doubt it, but if not there's always the subaru dealerships. if it has a subaru part number, they should at least be able to order it.
Old 09-23-2007, 02:47 AM   #9
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
brackets $116 shipped(IIRC) from Jamie @ subarugenuineparts.com
at least thats what i remember paying for them.
~Josh~
Old 09-23-2007, 12:49 PM   #10
rustylegacy
Member#: 140843
Loaded calipers come with the brackets, pads, and caliper. I dont know what the price is, but you can get it at the autozone web page.
rustylegacy is offline   Reply With Quote
Old 09-23-2007, 02:09 PM   #11
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Sweeeeet, Im basicly replacing the front-end on my Legy this week and I need to replace one of the brackets as well...I made a **** load of calls but no-one could give me a direct yes or no awnser.
Old 09-23-2007, 03:29 PM   #12
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
ok...Called AutoZone, here's what I got...
Autozone's computer's are ****** up! Its shows my car only available in an L, Brighton, or and Outback...no GT option? further more it shows the brakes on the Outback as the same as the WRX brakes...It dosn't seem to recognize that my car has the erlier "smaller" brakes either....
Hate to "brake" it to ya...AutoZone dosnt offer loaded rear H6 Calipers...I just checked.....and the unloaded ones are $183 a peice w/ a core charge
Old 09-23-2007, 06:14 PM   #13
rustylegacy
Member#: 140843
I just checked advanced auto, partsamerica.com. Look under 2001 outback, h6 rear loaded calipers are $71.48 w/ a $50 core charge.
Old 09-23-2007, 06:54 PM   #14
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Nice....I wound up calling them for my front end parts...Good prices,all in-stock,but they had the same issue with my brakes. I wound up being able to identify which rotors I needed by cross refrencing the other option to 02 wrx brakes....sure enough they matched.
Old 09-23-2007, 07:03 PM   #15
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
double post........
Old 10-03-2007, 06:15 PM   #16
Dan Cech
Member#: 67154
1997 Legacy GT/WRX
I went the advance auto loaded calipers route for my upgrade, if you're lucky they'll even take your old non-h6 calipers for the core
Dan Cech is offline   Reply With Quote
Old 10-03-2007, 06:19 PM   #17
jamal
Member#: 71875
98 2.5GT
my wheels fit
Fun fact: An SVX rear caliper bracket will work with the old style calipers to do an H6 upgrade.
jamal is online now   Reply With Quote
Old 10-03-2007, 06:35 PM   #18
breakfasteatre
Member#: 131662
1996 Legacy LS
that is a very fun fact!
To the suspension guru's...the final word on springs for STi Nytmare Brakes, Steering & Suspension 6 09-23-2004 08:41 PM
The Final Word on car theives 3BadHabbits Tri-State Area Forum 68 02-20-2004 10:17 AM
What I would call the final word on stock vs. STi plates with STi motor mounts North Ursalia Normally Aspirated Powertrain 11 09-10-2001 06:05 PM
The Final Word on EGT Guages. 2yLiTe Normally Aspirated Powertrain 17 11-11-2000 06:33 AM
Message Board Statistics All times are GMT -4. The time now is 12:58 AM.
