Old 08-30-2007, 05:38 PM   #1
bangis
Member#: 145885
2000 BE Legacy
Pearl
Angry knock sensor 1 need help
as the title say i am replacing my knock sensor 1 and dont know where to start any tips is appreciated
bangis is offline   Reply With Quote
Old 08-30-2007, 06:23 PM   #2
brandoncrone
Member#: 152710
THe knock sensor lives on the drivers side of the engine, sort of under the intake next to the throttle body. Its bolted to the block with a 12mm bolt. When installing a new one, don't torque the bolt to any more than 16 ft/lbs or the sensor will be damaged. Thats all there is to it.
brandoncrone is offline   Reply With Quote
Old 08-30-2007, 07:38 PM   #3
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
you have roughly an inch or two in diameter to squeeze your wrench with a extension in. have fun, first time took me 1hr. btw, it's a good idea to use a magnetic tool to get the bolt out once you have ratched it loose. hope this helps
choung
illegal2.2 is offline   Reply With Quote
Old 08-30-2007, 09:41 PM   #4
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Taking it out is the easy part. Figuring out how to get the bolt back in if you have a big hand is the challenge.
runninstrong is offline   Reply With Quote
Old 08-31-2007, 03:38 AM   #5
bangis
Member#: 145885
2000 BE Legacy
Pearl
thanks guys for the reply i already installed it and it was a lil challenge
Possible Knock Sensor Problem. Need Reliable Shop. Loyale93 Mid Atlantic Impreza Club -- MAIC 17 01-27-2010 10:34 PM
Prosport Boost gauge sensor wiring? Need help siksit Electrical & Lighting 0 09-04-2008 04:48 AM
SMC kit is knocking @ shift points, need help verc Water/Methanol Injection, Nitrous & Intercooler Cooling 10 02-15-2008 01:14 AM
Wires came out of oxy sensor plug. Need help kpiazzis Normally Aspirated Powertrain 0 09-08-2005 11:52 AM
Knock sensor? who needs that? lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 6 10-20-2004 07:54 PM
