Old 08-30-2007, 04:56 PM   #1
Slowturbo
Member#: 64804
07 WRX TR
Satin White Pearl
Default 07' WRX TR Stock Turbo Tuned by Moon Performance
Brought the car up to Moon Performance (Lake Placid NY) today to get the car tuned finally. Seth did an amazing job as always and was able to crank out some good power from the stock turbo. The car made 244awhp and 302ft/lbs The cars is def alot of fun on the streets with that much TQ.
Mods:
Invidia Catless DP
Invidia G200
ARC Intake
ARC FMIC
Walboro 255
Slowturbo is offline   Reply With Quote
Old 08-30-2007, 04:58 PM   #2
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
looks like KC or boost oscillation everywhere.....let the tuners chime in
bren wrx is offline   Reply With Quote
Old 08-30-2007, 05:02 PM   #3
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
Overall a very good tune though, good hp/tq given the basic bolt on mods.
Celtic1982citleC is offline   Reply With Quote
Old 08-30-2007, 05:44 PM   #4
SubieFiesta
Member#: 149426
2002 Subaru WRX
and 2005 Subaru STi
that tune need some help...
SubieFiesta is offline   Reply With Quote
Old 08-30-2007, 06:00 PM   #5
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
You should provide an explanation with your post so the rest of us can learn. It's difficult to take anything from such a vague statement.
Old 08-30-2007, 06:15 PM   #6
Auto0utcast
Member#: 127684
2004 WRX STi
hater, do you have a laptop? download enginuity and go for a ride with Jay and have him monitor things while you do a few WOT pulls... he can see any possible knock that way and see if the ecu is pulling timing. and also see if there is boost fluctuation. just a suggestion man.
Auto0utcast is offline   Reply With Quote
Old 08-30-2007, 06:18 PM   #7
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
Does that say 12.6 AFR?
ChrisSK is offline   Reply With Quote
Old 08-30-2007, 06:28 PM   #8
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
Travis,
The car was logged on the dyno and on the road when it was tuned yesterday. I think the only knock correction was a -1 somewhere in the powerband on 1 pull and the tolerance for timing pull was set to somewhere around 6. I highly doubt that anyone, in any world, on any dyno, would let a car leave if it were knocking and causing that much of an influx in power throughout the duration of a pull. As far as the boost goes the stock turbo (go Mitsu!) just doesn't seem to be able to keep up. Just means its times for a bigger (go Mitsu!) turbo.
Old 08-30-2007, 06:31 PM   #9
Slowturbo
Member#: 64804
07 WRX TR
Satin White Pearl
18g is sittin next to me hehe
Old 08-30-2007, 06:32 PM   #10
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
Edited
Last edited by Celtic1982citleC; 08-30-2007 at 07:28 PM. Reason: Correct dyno plot now posted
Old 08-30-2007, 06:35 PM   #11
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
Edited.
Last edited by Celtic1982citleC; 08-30-2007 at 07:28 PM. Reason: Correct dyno plot now posted.
Old 08-30-2007, 06:41 PM   #12
Auto0utcast
Member#: 127684
2004 WRX STi
hater.. sell the 18g boy... i got a nasty fp green with ur name on it
Old 08-30-2007, 06:43 PM   #13
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Originally Posted by Celtic1982citleC View Post
(car was tuned in Lake Placid, NY at a significantly higher elevation than where the customer lives) that the car runs with a lower AFR on the streets than indicated on the dyno.
so the car will be driven in a place where there is more oxygen and then run leaner? (lower elevation)
Then have a magical AFR shift after it gets of the dyno?
AFR, IMO, is a meaningless number without other parameters....timing, just to name one. If he's monitoring a -1 KC somewhere....it's probably enough knock to eventually, break a ringland.
Oil consumption FTW!
modaddict is offline   Reply With Quote
Old 08-30-2007, 06:45 PM   #14
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
*NOTE TO ALL*
Car also had an exhaust leak Forgot about that. Felt it should be pointed out.
Old 08-30-2007, 06:46 PM   #15
fourmicah
Member#: 128760
2012 Ruckus/WRX
Red&White/Gray
What PSI?
fourmicah is online now   Reply With Quote
Old 08-30-2007, 06:48 PM   #16
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
I believe he was tuned to around 15ish psi. But the poster or tuner would have to reply. I was just an innocent bystandard who was observing and having a good time.
Old 08-30-2007, 06:48 PM   #17
Auto0utcast
Member#: 127684
2004 WRX STi
yeah i couldnt see the AFR originally on the graph... 12.6 is lean as ****.
Old 08-30-2007, 06:54 PM   #18
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
Poster. Please post your "after" tune compared to the "stock". 07's are horrendously different than any other years for Subaru from what I understand. I just think we could all get a better grasp on what's going on with a before and after.
Old 08-30-2007, 07:04 PM   #19
Slowturbo
Member#: 64804
07 WRX TR
Satin White Pearl
AFR was 14.6 STOCK! new 07 ecu ftmfl! Thats some real scary ****! and i drove around like that for awhile w/o damage.
Old 08-30-2007, 07:07 PM   #20
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
And back yet again...talking to the poster...I think he posted a "mid-day" tune and not the final tune. He should be posting the final tune shortly. Silly poster.
Old 08-30-2007, 07:22 PM   #21
Slowturbo
Member#: 64804
07 WRX TR
Satin White Pearl
Heres a graph of the final pull. Much better AFR's. The dotted line is the stock (untuned) graph. Sorry bout that first graph! Feel free to rip the stock AFR apart haha.
Old 08-30-2007, 07:26 PM   #22
Celtic1982citleC
Member#: 156268
2011 WRX 5 Door
Satin White Pearl
There's the sheet I thought I was commenting on. Well done in getting the right plot posted. Congrats again on the results.
Old 08-30-2007, 07:29 PM   #23
Auto0utcast
Member#: 127684
2004 WRX STi
really hard to read the #'s but im assuming thats closer to an 11.6:1 afr... and yes i agree that the stock tune was garbage in comparison to the final product.
Old 08-30-2007, 07:43 PM   #24
zonker
Member#: 25771
02 wrx
white
Hey guys,
heres a bit of a run down of the tune...
The oscilation in the curves are the horrid boost control waggling around, dealing with way hot temps in the shop and some heat soak near the end of the day. We saw a torque peak of about 315 ftlbs right where the point in the second plot is, but that was backed off for a bit smoother onset of boost.
The KC map is smoothed to 6, throughout the day there was no timing being pulled from knock, there was one pull with way to hot IAT's that pulled a bit, but nothing that i would ever expect to see in the real world with real world air flow, this was due to some severe heat soak.
The first plot was a midway pull to try out some changes on the throttle duty maps, there is obviously some experimentation to be done with increasing duty to 100%, definately throws the fuel maps well out of calibration. so the duty cycle maps were set back to stock and mildy tweaked.
I could not get boost to hold up top, theres potential for much more whp if boost doesnt taper off so badly.....18g anyone??? i know its waiting...
MYIX8UR8 and Slowturbo's days both being awfully hot. sucks trying to combat heat soak etc, but at least you know the air can only get cooler.
the afr's are also set to 11.6 ish, im not a fan of 12's at all, makes power but it also makes way to much heat. the extra fuel gets used for thermal management, I prefer to set afrs on the rich end of whatever range the car is happy with for that exact reason, too rich and it breaks up, just a touch leaner and its happy and cool.
the 07 wrx turbo feels and tunes like the 1.8t's, good low end spool, not a whole lot of air up top, but makes for good useful torque where its fun to drive.
Thanks again for coming up guys, its always fun and amusing
cheers
seth
zonker is offline   Reply With Quote
Old 08-30-2007, 07:44 PM   #25
zonker
Member#: 25771
02 wrx
white
oh forgot to mention, the 07 sti is just as horrible in stock fashion with its closed loop delays 14.7:1 at torque peak!!!!! scary even, not a huge fan myself
seth
07' WRX TR RPM Jump Problem lolomgwtfbbqwrx Factory 2.5L Turbo Powertrain 10 01-03-2010 11:32 AM
20g w/ TMIC tuned by IA performance Phil Jr. Proven Power Bragging 88 03-06-2008 05:59 AM
04' STi tuned by MooN PerformancE Auto0utcast Proven Power Bragging 29 01-08-2008 05:39 PM
12.282 @ 112mph STi stock vf39 tuned by EQ tuning w/ minor mods downsti Proven Power Bragging 45 11-20-2006 06:25 PM
anyone been protuned/tuned by mzm performance? theairwaves Texas Impreza Club Forum -- TXIC 0 12-29-2005 03:35 AM
Message Board Statistics All times are GMT -4. The time now is 01:37 PM.
