Old 08-30-2007, 06:24 PM   #1
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Default Not hitting peak boost :(
I have tried a couple WOT runs to measure peak boost and the best I've had was a 14.1, after I disconnected the battery, pressed the brake a couple times and loaded the Real Time map of Stage 2 93 oct v1.30, which is also my base map.
Question now is what do I need to do to be at the Stage 2 boost level of 16.5 psi +- 0.7 psi???
Current setup is COBB catted DP, STi UP, STi midpipe, STi axleback, Accessport Stage 2 oct 93 v1.30 Base + Real Time maps loaded.
Also how should I go about measuring peak boost in the 4EAT, what gear should I be in and speed? And the boost levels are being read by the AP Live Boost feature.
eurospek is offline   Reply With Quote
Old 08-30-2007, 07:38 PM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Try the HWG map
Drac9 is offline   Reply With Quote
HELP turbo sounds weird and not hitting peak boost Adrenalinecrisis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-12-2010 05:25 PM
Not hitting peak boost with Accessport V2 and extreme taper. BrianMR2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 04-04-2010 11:00 PM
not hitting full boost :( subarooster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-09-2009 12:55 AM
not hitting peak boost with vf 34 blackrod punishment General Community 9 03-07-2006 09:45 AM
Not hitting target boost after an installation :( rukkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-15-2004 02:07 PM
