Old 08-31-2007, 12:10 AM   #1
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Default H6 rears on 97 LGT
I posted this on the general brakes and suspension forum, but i thought i would try with my fellow legacy brethren. I have searched and read everything I could but still have a question.
I bought loaded calipers for a 2001 Legacy, and it has the bracket on it. I also got the rotors, and I know the dust shield needs to be removed, but my question is if the piston is any bigger than my stock caliper, because I measured them and they seem to be the same size, so is the upgrade just a larger rotor? I read in the sticky, that the 02 and up wrx have the same caliper but just need the bracket to space the caliper further for the larger rotor, but is the 97 LGT caliper not compatible with the H6 bracket or something?
The sticky says that the 99-04 calipers are different from the 90-99, but they look almost identical other than the bracket. I just thought that the 99-04 calipers were supposed to be better (larger piston) along with being able to run the larger rotor, but it seems as if it is just the larger rotor, and compatibility with the bracket. Is this correct?
morrocco88 is online now   Reply With Quote
Old 08-31-2007, 01:09 AM   #2
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Well, I'm not entirely sure when the switch was made to the larger rear piston on all cars, but I can say for certain that your rear pistons are the same size as the H6 ones. And no, your caliper won't attach to that bracket. The change that happened somewhere around 98/99 concerned how the caliper attaches to the bracket, not the piston area. Even an old 90 Legacy wagon has the same size rear brake pistons and rotors as an 05 wrx.
jamal is offline   Reply With Quote
Old 08-31-2007, 01:11 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I don't know about piston sizes, but the older calipers are completely incompatible with the newer caliper brackets. You'll see when you take the old stuff off.
Old 08-31-2007, 10:28 AM   #4
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
ok thanks. So it is just compatability with the bracket. I do have the new calipers with bracket, but i wanted to make sure before I started smoothing the castings, and painting things. So the larger rotor is supposed to be a big improvement huh? I know it gives the caliper more leverage, but i just thought it would be a bigger caliper along with the lager diameter rotor.
Thanks for the quick replies. I'm going to tear everything apart real soon. here is the list of early Christmas goodies to go on.
H&R sport springs
KYB GR2's
wrx front brakes
H6 rears
SS brake lines
Old 08-31-2007, 10:33 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I did just the WRX fronts initially, then a few weeks later did the H6 rears. The car felt noticeably better under heavy braking (track and auto-x) with the H6 rears added into the mix.
Old 08-31-2007, 11:37 PM   #6
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Thats good to hear that it made a noticeable difference. I'm pretty excited to get everything put on. It will be hard to tell what did what since I'm doing so much all at once. Should be a huge upgrade to the way the car handles.
07 LGT rear brake set up vs. H6 rear txl146 Brakes, Steering & Suspension 3 03-06-2009 03:34 AM
H6 rears on 97 LGT quick question morrocco88 Brakes, Steering & Suspension 0 08-30-2007 11:54 PM
WTB: RS Rear Brake Upgrade. LGT, H6, Turbo Legacy. gregeyberk Private 'Wanted' Classifieds 2 05-02-2007 01:13 PM
WTB: RS Rear Brake Upgrade. LGT, H6, Turbo Legacy. gregeyberk NESIC Private Classifieds 0 05-01-2007 03:54 PM
OBX headers on 97 LGT mattvct Normally Aspirated Powertrain 10 07-01-2006 10:32 PM
