Old 08-31-2007, 02:36 AM   #1
JasoNeon
Member#: 86381
2004 2004 WRX Wagon
Default Can't connect to stock ECU with Tactrix cable.
Currently have the Cobb Accessport V1 on the car and was able to datalog with it still installed (married) to the car. I un-married it from the car which is supposed to set the stock ECU back to the factory configuration. After I did that I wasn't able to connect to the computer and reflash it using the tactrix cable. I was using all of the latest software, and tried every subaru listed to try and get it to connect and it never worked. It's a friend's cable and it works fine on his EVO and Legacy GT.
Also, we tried it with the green connectors connected, dis-connected, with the jumper wire, without the jumper wire, and all combinations. Any suggestions or ideas appreciated.
Jason
JasoNeon is offline   Reply With Quote
Old 08-31-2007, 01:24 PM   #2
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
to reflash or pull a map off the ecu the green connectors need to be connected as does the jumper wire.
as for the tactrix cable connection, make sure you are using the correct COM port on your computer. try using a different USB plug or set the com settings in the program to whichever usb port you are currently using.
KAX is offline   Reply With Quote
Old 08-31-2007, 02:23 PM   #3
Freon
Member#: 88322
2009 BMW 135i
You should be using the Openport driver within ECUflash. It does not require picking a COM port.
You definitely need the green connector and flash block connected. There is no use trying with either disconnected even as a troubleshooting step.
You must click the Read (or write) button in ECUFlash, get the pop-up box, and then you must turn the key to Run (not crank, not Acc) and press the OK button in ECUflash at as close to the same time as possible. If you turn the key and wait to click OK in ECUflash it won't work. If you click ok in ECUflash and wait too long to turn the key, ECUflash will fail before the car is even listening for the connection. People consistently screw this part up.
You can also check the white connector to make sure it is getting 12 volts.
Freon is offline   Reply With Quote
Old 08-31-2007, 03:33 PM   #4
WJM
Guest
Member#:
I still cant get mine to read...I started a new thread for mine.
Old 09-02-2007, 01:38 AM   #5
JasoNeon
Member#: 86381
2004 2004 WRX Wagon
Well we tried it about 10 minutes ago and I already forgot exactly what it said when we tried to connect but it was something along the lines of, "does have the required features to connect to this ecu". We again tried every car listed, and this was on a different laptop than last time.
I'm wondering if it's the wrong cable. The cable he has works on his 03 evo and his 05 legacy gt. He originally bought it for the evo (probably a 1.3M cable) and according to the page that lists what cable works with what car http://openecu.org/index.php?title=E...VehicleSupport that cable won't work with any wrx's except sti's. But that 1.3U (universal) says it will work with anything and looks identical to the 1.3M (mitsubishi) cable. Any ideas about that? If I can't figure anything out I guess I'll call a tactrix dealer next week and see if they've run into this before.
Jason
Old 09-18-2007, 04:01 PM   #6
benw
Member#: 103320
1998 swapped
Forester L
sounds like you've got the one for DBW and Evos. Won't work on the WRX
benw is offline   Reply With Quote
Old 09-18-2007, 07:42 PM   #7
JasoNeon
Member#: 86381
2004 2004 WRX Wagon
Yeah that's the only thing I could think of too but I thought it was weird that I could still datalog everything just fine. I called Tactrix today and they said the same thing pretty much so I ordered a Univeral cable that works with and Subaru.
Jason
Unable to send ECU init-check cable is connected and ignition is on bertune Open Source Reflashes 3 05-17-2010 11:12 PM
Can't connect to my god damn ecu! SueBaroo Open Source Reflashes 6 05-17-2010 06:56 PM
Unable to connect to romraider... possible wrong tactrix cable? All4bSpinnin Open Source Reflashes 15 04-29-2009 01:33 PM
To anyone with Tactrix cable Porkchop-WRX Tri-State Area Forum 2 08-04-2008 08:12 PM
Help can't connect to ecu 06 wrx spartanVR4 Open Source Reflashes 1 07-27-2008 09:12 PM
