Old 08-31-2007, 01:15 PM   #1
greysave
Member#: 62395
2005 STI
Default 04 STI throttle problem
I have a fully built motor, cams, ported heads, reworked crank, pistons, rods, ect. I am using hydra for my ems solution. When I step on the gas pedal nothing happens. I checked the hydra and it is getting 0 feedback. I had Phil check out the ems and it checked out ok. I am running a magnus intake manifold and I have the wiring harness grounds grounded on the intake manifold flange, and I have good voltage. I am running out of ideas here, the car has been down for a long time and I absolutely need it back up, anyone who has any idea please help.
greysave is offline   Reply With Quote
Old 08-31-2007, 02:55 PM   #2
greysave
Member#: 62395
2005 STI
t.t.t.
Old 08-31-2007, 09:55 PM   #3
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris [email protected]
so is it that the car starts up fine, but just has no throttle response?
Spec_C is offline   Reply With Quote
Old 09-01-2007, 03:14 AM   #4
xXSTi-lynXx
Member#: 131762
2005 STi-"casper"
white on white !
igniton problems???? check coils is my bet.
does it burn oil??
smoke??=
xXSTi-lynXx is offline   Reply With Quote
Old 09-01-2007, 11:20 AM   #5
greysave
Member#: 62395
2005 STI
Exactly.
does it burn oil??
smoke??=
No ignition problems, just throttle problems. No throttle response.
Old 09-01-2007, 12:21 PM   #6
MrTransAm
Member#: 80744
2005 Subaru STI
I'm thinking of going to Hydra,.did the car run fine on initial setup or have issues from the start of the Hydra setup? I'm just curious if it could be EM issue.
Also I'm just trying to see if you can pinpoint the start of your problem more.
MrTransAm is offline   Reply With Quote
Old 09-01-2007, 12:35 PM   #7
greysave
Member#: 62395
2005 STI
The hydra went in at the same exact time that I did my rebuild. I have subsequently sold my stock ecu since then. I could not have used my stock ecu any way, because of my fuel system modifications. It did give throttle feedback before the hydra though before a reputable tuner spun a rod bearing in it on the initial break in, but that was on the stock ecu before these major fuel modifications. I did send the hydra back to phil who said that it ran good on his car. He did mention sending my wiring harness back to hydra, but I haven't been able to get in contact with him on the later half of the week so I guess that will have to wait until tuesday. Is there any chance of a bad tps?
Greg
Old 09-01-2007, 01:07 PM   #8
jays05
Member#: 78165
05 STI 35r + e85
Can you measure the voltage right off the TPS?
jays05 is offline   Reply With Quote
Old 09-01-2007, 03:26 PM   #9
greysave
Member#: 62395
2005 STI
Thats a good idea, I will try that.
Old 09-11-2007, 10:27 PM   #10
greysave
Member#: 62395
2005 STI
It was the wiring harness. Damn Finally.
Westchester ny 04 sti throttle body & fogt light covers 04aspenwrx Tri-State Area Private Classifieds 6 08-23-2009 11:19 AM
04 sti throttle body F/S in westchester!!! 04aspenwrx Tri-State Area Private Classifieds 0 07-10-2008 06:42 PM
06 STi Motor into and 04 STi, what problems will I run into? stillillmatic7 General Community 1 05-01-2007 07:52 PM
FS: 04 Sti Throttle Body Sap12687 Private 'For Sale' Classifieds 2 05-19-2006 09:16 AM
04 STi throttle body, TGV's, injectors, coils, harness Hondaslayer Private 'For Sale' Classifieds 19 07-30-2005 11:30 AM
