Old 09-01-2007, 01:51 PM   #1
stockdad
Member#: 79448
Default Question about how much MT oil to add to my 04 FXT
It appears the oil level of my 2004 Forester XT is just above the L/circle on the dipstick. The manual says to add GL-5 oil, but how much would bring it up to the F/circle on the dipstick?
Thanks.
stockdad is offline   Reply With Quote
Old 09-01-2007, 06:05 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
usually the difference from low to high on the dipstick is less than a quart (for engine oil, anyway - can't imagine it's that different for the transmission)
Old 09-05-2007, 04:11 PM   #3
gandapanda
Member#: 51476
05 FXT
16 Golf R
How does this level get low...? It's a sealed system, right?
Also, did you have any symptoms that led you to to the tranny, stockdad?
gandapanda is offline   Reply With Quote
Old 09-05-2007, 10:20 PM   #4
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
I always had so much trouble reading the fluid level on the 5MT dipstick. I just changed the tranny fluid this weekend, and filling it, it was near impossible to tell where the fluid was on the line, other than a dollop of oil collecting at the bottom of the stick.
Mind is offline   Reply With Quote
Old 09-20-2007, 04:31 PM   #5
gandapanda
Member#: 51476
05 FXT
16 Golf R
I had the same issue... I ended up filling up a quart, and then pumping out a quart...
How much extra oil do you add w/ an oil cooler installed? prototypeWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 09-05-2006 10:39 PM
Help me find the thread about how much it is to convert a 20g to a Green. eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-16-2004 05:08 PM
how much Toulene to add to 1/2 tank? westy66 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-17-2002 08:05 PM
How much weight does AWD add compared to 2WD? Fubaru Newbies & FAQs 1 04-28-2002 10:44 AM
Question about how much my car is worth... Syms Vancouver Impreza Club Forum -- VIC 4 01-24-2001 07:27 PM
