Old 09-01-2007, 07:09 PM   #1
adWRXi
Member#: 130288
Default why wont my car connect with the programs??
i have an 04 wrx. i have the tactrix cable and the white jumper. i downloaded ecuflash 1.31.1396 and enginuity 0.4.1
the problem is, none of these programs are picking up the car.. i connected the white jumper to wheres its supposed to go and connect the two green plugs. then i connected the taxtrix to where thats supposed to go and connect the usb side to the laptop.. then when i open ecuflash it doesnt give me an option to do ANYTHING..
heres a screenshot: http://img.photobucket.com/albums/v3...uflashprob.jpg
it looks like this no matter what i do.. it wont let me click "read ecu" or anything
WHY ?!?!
thanks in advance for the help!!
adWRXi is offline   Reply With Quote
Old 09-01-2007, 10:04 PM   #2
Spiider
Member#: 13680
You don't have the drivers for the Tactrix cable installed.
I can easily see that in the "error loading FTD2XX.dll" message.
You need to install the FTDI driver package.
Spiider is offline   Reply With Quote
Old 09-02-2007, 02:49 AM   #3
adWRXi
Member#: 130288
where do i get the driver???
Old 09-02-2007, 04:55 AM   #4
Nuke209
Member#: 108089
2003 WRX
NF Performance
It's in there, should've installed when you installed the software
i suggest you uninstall ecuflash and reinstall it again.
Nuke209 is offline   Reply With Quote
Old 09-03-2007, 05:05 AM   #5
wherethefmi
Member#: 124318
1989 Taurus SHO
Oxford White
no all you need to do is when you plug in the tactrix cable is to have the computer find the drivers for you. there should be a dialog box pop up saying that new hardware was found. click the ok button it will work.
wherethefmi is offline   Reply With Quote
Old 09-03-2007, 02:35 PM   #6
hex2bit
Member#: 135072
2004 FXT, 19t-td04
What Operating System are you running? Windows XP, Vista? I know with XP, you can block the installation of unsigned drivers, which would block the installation of the drivers you need for the cable. Typically it's set to prompt you, but I've seen some people with it set to block.
hex2bit is offline   Reply With Quote
Old 09-03-2007, 11:55 PM   #7
adWRXi
Member#: 130288
thanks guys for the help!! it connects now!! now i just need to learn what key position it should be in and how to load maps!! haha
Old 09-10-2007, 10:07 PM   #8
slvrwrx03
Member#: 155183
2003 WRX
Default same problem
I have the same problem Im trying to use the tactrix cable with enginuity to datalog my 03 WRX but I cant connect and when the dialog box comes up to search and install the program for the cable it always fails to find to drivers any help would be great
slvrwrx03 is offline   Reply With Quote
Why is my car surging with constant low throttle? fnlyfnd Open Source Reflashes 23 05-19-2009 01:51 PM
Why does my car pull to the left and also is it dangerous? subyboy828 Newbies & FAQs 11 08-15-2007 06:04 PM
Why does my car pull to the right? qik-RE Newbies & FAQs 11 10-25-2004 03:58 PM
Why wont other car companys join the wrc? WRXMaster Motorsports 44 10-28-2002 01:28 AM
what is the dealer going to say to me if i take my car in with the intake on? inpreza kid Canada Region Forum 20 03-09-2001 12:00 AM
