Old 09-01-2007, 10:05 PM   #1
shootsbrah
Member#: 152641
Default problem with 4eat. need your help!
2002 wrx wagon 4eat with around 75,000 miles, car is completely stock.
problem:
when im at a stop light, i feel a vibration comming from under the car. i shift into neutral and the vibration goes away, i shift back into D and the vibration returns . while driving, the car shifts smoothly with no problems. i only feel the vibration while im at a complete stop and goes away once i step on the gas pedal. i noticed that while the car is at idle and i let off the brake, my car barely moves. i also noticed that there is a buzzing sound comming from under the car when the car is in gear or reverse and goes away if i shift into neutral. anyone know or have an idea of whats going on? thanks!
shootsbrah is offline   Reply With Quote
Old 09-01-2007, 10:52 PM   #2
TopSecret_Gold
Member#: 113994
2004 WRX Impreza
I wonder if it could be something with the torque converter or even the valvebody? About where do you hear the buzzing and feel the viberation?
TopSecret_Gold is offline   Reply With Quote
Old 09-02-2007, 01:42 PM   #3
zrl
Member#: 69153
is your idle speed right?
mounting gone bad?
zrl is offline   Reply With Quote
Old 09-04-2007, 04:50 PM   #4
blueb3
Member#: 108471
when was the last time you replaced the fluid?
blueb3 is offline   Reply With Quote
Old 09-04-2007, 08:28 PM   #5
nardvark
Member#: 145108
2002 Impreza TS
How loud / strong of a vibration?
Is this new?
I wouldn't worry if it's just at idle and not rattling your teeth.
The reason it goes away in neutral is because your engine isn't under load, so its resonance point has changed.
If it's shifting smoothly through the gears, I don't think I'd worry about the transmission. I'd look more for a loose / rattling piece of the exhaust system.
nardvark is offline   Reply With Quote
My rs project rs420 Vancouver Impreza Club Forum -- VIC 31 06-07-2010 12:12 AM
Problem with 4eat. Please help. CapMitsubo Transmission (AT/MT) & Driveline 3 04-13-2009 05:52 PM
Problems with brakes, need some help. Smoby Brakes, Steering & Suspension 3 05-19-2006 01:18 AM
problem with utec need your help dlowman UTEC 6 04-04-2006 08:18 PM
OT need your help with lower back problems RSimport Off-Topic 19 09-18-2005 10:03 PM
