Old 09-02-2007, 05:29 PM   #1
WhiteH2O
Member#: 452
'06 GX470
Default Another sunroof problem
I just got an '98 LGT that had one of those sunroof deflector things, but my kayak racks didn't fit on with the deflector, so I took it off. The previous owner had the sunroof unplugged because it wasn't sliding on the track right. I plugged it in, and moved it back about 4" or so to get the deflector off. Got it off no problem, but now the sunroof won't go back up all the way. I got it to move back forward, but it won't go back up to be even with the roof. I tried the motor and I tried the allen wrench to get it back, but it must be off the track or something. Now I can't get it to move much at all. I just want to get it back up even with the roof so it will be watertight. Does anyone know what I might have to do to move it up 1/2" in the back? Thanks in advance...
WhiteH2O is offline   Reply With Quote
Old 09-02-2007, 06:58 PM   #2
Bakergtt
Member#: 59207
'05 X was 98 LGTT
So its all the way forward just not slid up to mate with the roof? have you tried helping it with a little muscle and using the switch at the same time?
Bakergtt is offline   Reply With Quote
Old 09-02-2007, 07:09 PM   #3
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Sorry for this not being helpful. But my car did the same thing. I just brought it to the shop and they fixed it in under an hour.
Frogsthatmoo is offline   Reply With Quote
Old 09-02-2007, 08:50 PM   #4
WhiteH2O
Member#: 452
'06 GX470
Yes, and yes.
I can see what is supposed to happen when it works. There is a part on the back of the sunroof on the tracks that pushes the rear of it up to mate with the roof, and it doesn't move. I can push it up to where it should be, but it won't stay. If anyplace was open today, I would probably just take it in and see if they could do it really quickly, but everyone is closed for the next few days.
Old 05-24-2008, 10:44 AM   #5
Christopher UK
Member#: 100588
That happened to mine also. That back track ended up getting bend and i had to pull it out. I'm hoping that i can just buy that one piece and not the whole track.
Christopher UK is offline   Reply With Quote
Old 10-13-2008, 06:36 PM   #6
WhiteH2O
Member#: 452
'06 GX470
Bump this old thread back up.
I got my sunroof to somewhat stay in place and unplugged the stupid thing and forgot it was there. Lately, it has been opening up a little and making noise. Also, because winter is coming, I don't want it to be leaking. Started messing with it again, and it is worse than it was. Came to see if there is anything helpful on here, and ran into this:
http://www.scoobymods.com/forums/showthread.php?t=3709
Has anyone tried this, and does anyone have an idea how long it takes, how hard it is, and are there any better pictures out there?
Old 10-14-2008, 08:47 AM   #7
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
i saw that a few years ago and was going to attempt to fix mine, but ended up not doing it. let us know if you do it how well it goes as it would be a great fix for many
legacy1907 is offline   Reply With Quote
Old 10-14-2008, 10:57 AM   #8
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
I would do it just to see if it fixes the seal.
All I know is that when my sunroof stops working I'll be removing the entire thing and having a welded plate installed. I hardly ever use it. I could have a lexan window installed too I suppose.
At least removing it I'll be saving about 100lbs in weight.
Huffer is offline   Reply With Quote
Old 10-14-2008, 11:41 AM   #9
WhiteH2O
Member#: 452
'06 GX470
I got lazy and ended up with another temp fix yesterday. I cut a metal bar (3/4" by 1/4" by a few feet) and shoved it in under the mechanism that lifts the sunroof so that it holds it in place. Then I shut the opaque cover thingie under it. Good enough for government work.
I am wanting to get my car painted in a year or so, and at that time, I am going to try to do something drastic about it. I like the big weight saving of removing 90% of it, might leave the window, but it won't be able to move afterwards.
help: sunroof problem Gil Legacy Forum 4 07-12-2006 12:43 PM
sunroof problems? kokepelli Forester Forum 5 03-10-2004 04:46 PM
Sunroof problems WRC1 General Community 14 02-05-2004 09:47 PM
Sunroof problems prelude/2.5rs Newbies & FAQs 4 03-28-2002 03:59 PM
('93-'01) Sunroof Problem SubyBean Impreza Forum 2 04-18-2001 08:09 PM
