Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 09-02-2007, 06:44 PM   #1
shnibop
Member#: 140235
2004 sti
java black pearl
Default DSpecs+Cusco rear camber plates fit?
this might be a dumb question, i did some searching but came up empty.
will rear cusco pillowball camber plates fit tokico d-specs?
cusco p/n 658 420 a
also these camber plates will fit an 04 sti?
ps. i checked the compatibility sticky and am still not sure, i'm retarded, sorry
shnibop is offline   Reply With Quote
Old 09-03-2007, 05:48 PM   #2
noboost4u
Member#: 126442
My car is slower
than your car
Pretty sure the Cusco rear plates will only work with a full coilover setup. As in a replacement for COs with just rear pillowball setups.
Not positive though, just the only way I've seen them used.
noboost4u is offline   Reply With Quote
Old 09-03-2007, 07:13 PM   #3
shnibop
Member#: 140235
2004 sti
java black pearl
you know i did find a decent amount of posts where wagon guys were running the front camber plates and the strut nut wouldn't fit inside the housing on the plate. i guess they come with a special nut that should fit inside the housing.
Old 09-03-2007, 08:52 PM   #4
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
You will need a special nut to fit inside the ball on the camber plate for the Cusco rear plates with any other strut than Cusco Zero 2R's. I am getting a set made right now for mine.
speedyHAM is offline   Reply With Quote
Old 09-03-2007, 10:44 PM   #5
shnibop
Member#: 140235
2004 sti
java black pearl
could i simply grind off the lip that runs around the nut on the dspecs? or would that be dangerous, i read a thread where some guy did that on a lathe. thoughts please
Old 09-04-2007, 12:12 AM   #6
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Camber plates will not work with the DSpecs if you are using stock diameter springs. The rear cusco plates assume that you have a rear upper spring perch (for a coilover) and the stock diameter spring use the upper spring perch integrated with the stock type rear tophat.
Arnie is offline   Reply With Quote
Modified Noltec Race Camber Plates and Cusco Rear Camber Plates leonbmx NWIC Private Classifieds 13 09-02-2009 11:34 AM
FS VA: Cusco Front Camber Plates. Fit 02-07 GD Impreza. mav1c Suspension/Brakes/Handling 4 11-29-2008 11:47 AM
Will GC8 Cusco front camber plates fit a GD front strut? esper Brakes, Steering & Suspension 9 06-17-2005 03:20 AM
WTT: New STi Grp-N 02/03 Rear Strut Mounts for Cusco Rear Camber Plates GoRacerXGo Private 'For Sale' Classifieds 4 05-09-2005 03:21 AM
Cusco Rear Camber Plates Question amwrx Brakes, Steering & Suspension 8 07-14-2002 11:52 AM
