Old 09-03-2007, 02:36 AM   #1
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
Default [email protected]: Bolt-on S4 with OEM RS4 K04 turbos
Stock 2.7T block (APB)
Stock rods, pistons, and crank
Stock displacement and compression ratio
Stock cylinder heads, head bolts, and gaskets
Stock cams, springs, and retainers
Stock intake & exhaust manifolds
Stock electronics & engine management (Bosch Motronic 7.1)
Stock ignition system
Stock transmission
Stock driveshafts
Stock axles
Stock rearend
Mods:
OEM RS4 K04 turbos (full boost at 3700rpms)
26psi spike tapering to 22 at redline
AWE intercoolers
AWE MAF
Bosch Greentop Injectors
RS4 fuel pump
GIAC Stage 3 software
Adaptive channel tweaking with Lemmiwinks, ECUx, and NGK AFX Wideband O2.
APR Downpipes
VP C16 (used for extra protection, all that's really needed is 103-104 octane)
NO nitrous!
[email protected] video link:
http://titsup-racing.com/video/s4/s4_10_73.wmv
BlownCobra is offline   Reply With Quote
Old 09-03-2007, 04:00 AM   #2
STimo
Member#: 110273
450 whp 30R STI
[email protected]
Unless the car was COMPLETELY stripped i dunno, id be VERy impressed as these are pretty heavy cars.. You sure he wasnt running twin GT28s?? Cuz not one but TWO of my buddies run the exact same setup and on 110oct they're good for 11.8-12.00 @ 118-120 in a full weight.. I believe they run 25psi with a 1-2 taper..
STimo is offline   Reply With Quote
Old 09-03-2007, 04:17 AM   #3
LA_STI
Member#: 145721
2004 STi
JBP
that was pretty damn sweet
LA_STI is offline   Reply With Quote
Old 09-03-2007, 04:21 AM   #4
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
It's my car and yes it's stripped, although not quite completely just yet.
Right now my 60fts are in the 1.68 to 1.72 range. Absolutely garbage. I need to get them down into the low 1.5 range and then I think I'll be running 10.3 to 10.4.
Old 09-03-2007, 04:26 AM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i thought a couple guys got into the 10's on the stock block but i cant find them right now
10.7 STI. it has forged internals, but stock heads
http://forums.nasioc.com/forums/showthread.php?t=894763
11.2 @ 128 mph, stock block head and clutch
http://forums.nasioc.com/forums/showthread.php?t=588640
Old 09-03-2007, 05:05 AM   #6
downsti
Member#: 63179
2006 Stock Turbo STi
[email protected] VF39
nice car.. even more badass on 1/4time
im seen your car around alot on many video and couple of my friends knows about your car.
i heard your car is only 2700lb with you in it
is that true?
one fellow racer friend owns a s4 with the same set up as you said that
just want to know if its true
downsti is offline   Reply With Quote
Old 09-03-2007, 08:32 AM   #7
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
nice.
any pics?
whats the difference between RS4 turbos and a S4 turbo?
stickman is offline   Reply With Quote
Old 09-03-2007, 12:45 PM   #8
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
I'm not trying to turn this into an "S4 is better than Subaru" thread. I just thought some of you might enjoy seeing what's going on with other platforms.
Old 09-03-2007, 12:46 PM   #9
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
is that true?
Yup, it's around 2750-2800 with me in it. Where are you guys from?
Old 09-03-2007, 12:58 PM   #10
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
Originally Posted by stickman View Post
nice.
any pics?
The stock S4 turbos are K03s. They're tiny, blow all the time, and capable of about 320whp max. The RS4 turbos are K04s, very reliable, and capable of around 500whp. The turbos from the Audi RS6 are also K04s, but quite a bit bigger than the RS4 turbos. That's what I'll be upgrading to next. They're good for about 75-100whp over RS4 turbos, so I'll be shooting for a high 9 second pass if I can get the 60ft down to 1.50 or so.
Here are some pics:
Old 09-03-2007, 01:40 PM   #11
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Congrats Marc!
Hope youve been well, thats one helluva pass there! I know youve been trying to break 10s since you bought that thing, what did you change to get there? Weight reduction, tuning? or just a really good pass?
Paul
PaulRex is offline   Reply With Quote
Old 09-03-2007, 01:48 PM   #12
Member#: 156622
Stock transmission
Stock driveshafts
Stock axles
Stock rearend
Mods:
AWE intercoolers
AWE MAF
RS4 fuel pump
APR Downpipes
NO nitrous!
Nice run Marc , congradulations on going in the 10's , i also want to thank you for putting together the video of my car at Island Drag way . See you Weds before we go to the track for a dyno session hopefully you can extract a little bit more power from her and go a little bit faster ! - Jimmy
JK@THESHOP is offline   Reply With Quote
Old 09-03-2007, 02:00 PM   #13
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Very sweet! Got any engine bay pics?
z is offline   Reply With Quote
Old 09-03-2007, 02:14 PM   #14
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Holy hell that thing is stripped!
Might want to update your first post with weight #'s, that is quite an important factor.
Swine is offline   Reply With Quote
Old 09-03-2007, 02:18 PM   #15
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
Originally Posted by PaulRex View Post
Congrats Marc!
Paul
Damn Paul, you're still alive? I had no idea!
You moved to Vermont? What's going on over there?
Same old sh|t with me... Still addicted to cars/street racing/etc.
The 3 tenth and 3-4mph improvement came from more boost and some fine tuning. My car was pig rich before (went 10:1 at 5500rpms and never returned), so I saw some nice gains from leaning it out. I now run around 12.5 AFR. Car seems to make the most power there. I also gained power from turning up the boost.
Still got the WRX?
Old 09-03-2007, 02:20 PM   #16
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
Thanks dude. Unfortunately it doesn't look like Island is open this Weds. night like I had thought. They stopped the first Weds. of the month racing thing back in August. So I guess you guys will go to E-town instead? I might still go... I'll just take Maggie.
Old 09-03-2007, 02:21 PM   #17
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
Yeah, I should also update my first post with the amount of money I've spent on this car which is currently $11,000 including the cost of the car.
Old 09-03-2007, 02:22 PM   #18
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
That's SUPER light man. That thing is way stripped.
Impressive even if stripped. Congrats on the 10s.
SilverSurfer04STi is offline   Reply With Quote
Old 09-03-2007, 02:23 PM   #19
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Is it a salvaged S4 or something? Did you buy it after bank repo'ed it from some poor schmuck? That's literally dirt cheap.
Old 09-03-2007, 02:27 PM   #20
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
Here are a couple from different intake/intercooler setups. I now run an intake that's different than the two shown below.
Old 09-03-2007, 02:28 PM   #21
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Originally Posted by SilverSurfer04STi View Post
Is it a salvaged S4 or something. That's literally dirt cheap.
Yeah and vw/audi stuff isnt cheap, which means the car must have been uber cheap. Im sure around 700-1000 of the $$ went to those wheels and bfg radials.
My oldest brother had an apr stage 3 a4 and my middle brother had a apr stage 2 b4 passat.
I wasnt trying to take anything away from you BC from asking you to update your first post...but you tell us everything you have done EXCEPT for weight savings in the first post? Why? Do you consider this not important?
Old 09-03-2007, 02:30 PM   #22
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
Thanks. I'm a strong proponent of weight reduction because it's cheap, makes the car more reliable, and not only greatly enhances acceleration, but cornering, braking, and fuel economy too!
I'm looking forward to actually making some real engine mods... GT2871RS turbos, built 3.0L motor, some head work, cams, etc. This car should fly with 800-900 WHP.
Old 09-03-2007, 02:33 PM   #23
BlownCobra
Member#: 40812
1991 Dodge Spirit
It's my grandma's
Because I thought this was a forum about power bragging, not weight reduction bragging. If you guys want me to brag about weight reduction, I can tell you about all the research, creativity, dedication, and thriftiness that went into removing 1,000lbs from a 3,600lb car. Hint: Less than 100lbs of that thousand was cut out of the car so spare me all the wise ass cracks about how easy it is to bust out the sawzall.
Contrary to popular belief, VW/Audi parts are pretty damn cheap, especially if you know where to find stuff. I have a friend that buys salvage S4s at the auction for only a couple grand and parts them out. Even new, the parts aren't that expensive. For example, I run OEM Audi TT diverter valves and they run $32 each new.
The rear wheels I run are OEM CLK320 MB rims. I got a set of 4 for $50 in Craigslist. The rear Hoosier drag radials were $200 shipped. The set of SSR Comps with BFGs have since been sold. I now run Kosei K1 TS rims in the front which I got for $450 for a set of 4. The front BFG drag radials I'm borrowing from my buddy's Evo.
The reason why I have so little in my car is because over the course of about 3 years I was able to sell just about every part that I removed for weight reduction. The alcantara seats, airbags, airbag module, door panels, carpeting, headliner, sunroof assembly, misc. covers/moldings, climate controls, stereo, speakers, ABS module, side skirts, rear valence, etc. adds up fast. I got thousands and thousands of dollars for that crap.
The other reason is because I was fortunate enough to pick up a few sponsors who gave me free aftermarket parts. I was then able to make even more money by selling the aftermarket parts that came on the car when I bought it back in the end of 2003. When I bought it in '03, it already had the K04s and a bunch of other mods, so I saved some more money there as well.
I'm not saying my car could be duplicated for $11,000; only that $11K is what I currently have into it including the cost of the car itself. Keep in mind this price doesn't include the labor that myself and friends put into the car. We spent a ton of time with the weight reduction alone. For example, we re-wired the entire car and removed 44lbs worth of wiring alone! This was a huge job.
With that said, S4s are getting really cheap. With a clean title, you can get one with high miles for $6K to $8K. They're even cheaper at the auction. If you play your cards right, you could buy a 6spd S4, completely gut it, sell all the parts, and wind up with a RUNNING S4 for a few grand or even ZERO money!
Old 09-03-2007, 02:36 PM   #24
04caliwrx
Member#: 157842
2004 wrx
wow that car is just nuts man! but why does it look lifted?
04caliwrx is offline   Reply With Quote
Old 09-03-2007, 02:39 PM   #25
wrxty
Member#: 121996
That was a nice run. Whats the supsension setup?
wrxty is offline   Reply With Quote
