Old 09-03-2007, 09:50 AM   #1
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Default Andrewtech / TurboXS Strikes Again! 05 STi - 517 WHP T3/T04S
First, a little background on this car. I purchased it in January 2007. The day after I picked it up, the car developed and oiling issue, and long story short, the engine blew. While it is neither here nor there, I believe the previous owner knew it was coming, and that's one of the reasons he got rid of it.
I then sent the car to Andrewtech to be repaired and built. Mods are as follows:
2005 Aspen White STi
Weisco Coated Pistons
Eagles Rods
ARP Head Studs
Calico Coated Engine Bearings
Ultimate Racing T3/T04S Turbo (.82 a/r)
Ultimate Racing 1000cc Top-Feed Injectors
Ultimate Racing Fuel Rails
Dual In-Tank Whine-bro 255 LPH Fuel Pumps
Fuel Pressure Regulator
Ultimate Racing 3" Down Pipe
Ultimate Racing Up Pipe
TiAL 44mm Wastegate w/ Dump Tube
Perrin Semi-Equal Length Header (wrapped)
Invidia Turbo-Back Exhaust
Ultimate Racing Front-Mount Intercooler
Ultimate Racing Polished Intercooler Piping
TiAL Blow-Off Valve
Ultimate Racing Cold-Air Intake w/ MAF Housing
TurboXS DTEC 4 bar Pressure Sensor
TurboXS UTEC w/ Map Switch
TurboXS Manual Boost Controller
Exedy Twin-Plate Clutch
Kartboy Shifter Bushings
Kartboy Short-Shifter
Skunk2 Lowering Springs
Cusco Rear Stabilizer Bar
Cusco H Brace
Function7 Pitch Stop
2006 STi Rear Diffuser
STRI Boost, EGT, Fuel Press, Oil Press gauges
Viper Alarm / Remote Start
Hella Supertone Horns
The car put down 431WHP / 388WTQ on pump gas, on race gas, it did a strong 517WHP / 472WTQ. In my opinion, there's a little more in the car. The race gas tune was done with over 1/4 tank of 93 and only about 4 gallons of C16.
Special thanks to Andrew, Edwin, Jake, and all the rest of the guys at Andrewtech, and Jermaine @ TurboXS for staying up through the early morning hours tuning my car.
Teh Legacy is offline   Reply With Quote
Old 09-03-2007, 09:52 AM   #2
Nuked
Member#: 110329
2016 WRX Premium
ISM
congrats man, car is def sick!
SQ
Nuked is offline   Reply With Quote
Old 09-03-2007, 10:22 AM   #3
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
killer setup man! congrats on the amazing car.
can you post your opinions and pictures of the UR injectors and fuel rail setup. how was the install? Thanks in advance!!
cnstman is offline   Reply With Quote
Old 09-03-2007, 10:35 AM   #4
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Well, I get HORRIBLE gas mileage, but I'm pretty sure it has something to do with the Ecutek flash. I need to get my ecu flashed back to stock.
I didn't install them, so I don't know how the install was, sorry.
Old 09-03-2007, 10:10 PM   #5
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
I can't wait to get my car back from Andrewtech.....I hope to be close to where you're at with the GT30R .82 on built motor. Are you going to take it to the track once it is broken in?
TAPOUT is offline   Reply With Quote
Old 09-04-2007, 01:50 AM   #6
spoolindc2
Member#: 72972
2003 WRX Stage 2 HKS
sweet setup... I love the t3/to4 turbo... good spool excellent power band!!!
spoolindc2 is offline   Reply With Quote
Old 09-04-2007, 02:47 AM   #7
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
how bad is the gas milage? How far are you able to get on a tank?
jigga is offline   Reply With Quote
Old 09-04-2007, 08:09 AM   #8
Teh Legacy
Member#: 9853
to keep your mouth
shut.
It's already broken in, and it's going to the track this Friday. I just need to find some C16 before then!!! Anyone around Morgantown WV / Pittsburgh know of anywhere?
Old 09-04-2007, 08:09 AM   #9
Teh Legacy
Member#: 9853
to keep your mouth
shut.
REALLY bad. Just over 150 miles a tank right now. I'm almost positive it's the EcuTEK flash. It needs to go.
Old 09-04-2007, 08:25 AM   #10
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
and I thought I was bad eeking out 250 miles to a tank spending most of that on the highway
but then again, I can blame my short 6th gear on my JDM 6MT for that
EDIT: I see you are running some really large injectors there, and from what i have been told, they are the culprit of some pretty nasty gas milage in our cars even when tuned to run the proper AF ratios and the like...shame, since they are needed too for the higher power setups...
Old 09-04-2007, 08:37 AM   #11
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
cool beans
THE-95-STi is offline   Reply With Quote
Old 09-04-2007, 09:50 AM   #12
Imprezd
Member#: 3357
This was a seriously fast car on the road! Enjoy Man!
Imprezd is offline   Reply With Quote
Old 09-04-2007, 10:02 AM   #13
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Thanks, Jermaine! You did an AWESOME job. I'll be back up there soon.
Old 09-04-2007, 10:03 AM   #14
Ultimate Racing
Member#: 101728
2002 Impreza WRX
Congratulations! Glad to hear everything finally came together for you.
Darryl
www.ultimate-racing.com
Ultimate Racing is offline   Reply With Quote
Old 09-04-2007, 10:07 AM   #15
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Darryl
Couldn't have done it without your customer service. Thanks again for taking care of everything!
Old 09-04-2007, 12:15 PM   #16
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Something is going on at 5200 rpm There is a huge dip in power and trq.
CLark
AZScoobie is offline   Reply With Quote
Old 09-04-2007, 12:49 PM   #17
Teh Legacy
Member#: 9853
to keep your mouth
shut.
CLark
The dyno was overheating and getting pissed off.
Old 09-04-2007, 12:53 PM   #18
AZScoobie
Member#: 8785
netcom.com
SO it cause the car to knock?
C
Old 09-04-2007, 01:01 PM   #19
Teh Legacy
Member#: 9853
to keep your mouth
shut.
C
I had ZERO counts of knock on any of my maps. Like I said, the dyno was overheating and some readings were off. You can ask Jermaine if you like - he tuned it.
Old 09-04-2007, 01:10 PM   #20
the aaron vaccar
Member#: 77255
Turbo XS and Andrewtech do great work!
the aaron vaccar is offline   Reply With Quote
Old 09-04-2007, 01:59 PM   #21
Ultimate Racing
Member#: 101728
2002 Impreza WRX
CLark
I was thinking it was a boost spike. EBC?
Darryl
Old 09-04-2007, 02:04 PM   #22
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Darryl
TurboXS MBC.
Old 09-04-2007, 02:38 PM   #23
Ultimate Racing
Member#: 101728
2002 Impreza WRX
Boost overshoot?
Darryl
Old 09-04-2007, 02:51 PM   #24
Teh Legacy
Member#: 9853
to keep your mouth
shut.
I don't have anything other than the bitmap I posted, but maybe Jermaine can chime in and shed some light. . .
Old 09-04-2007, 03:18 PM   #25
Imprezd
Member#: 3357
C
No knock, the dip was from a small rich spot in the map. It started very slightly in the pump gas tune and by the time we got to the Race gas tune it got slightly worse. Dyno overheated on the 2nd or 3rd Race gas pull before I could clean it up. As you can see the car made a max of 520whp ish as the dyno over heated. We took the car out for the road tune to clean up the map.
Car is awesome no knock in sight.
Jermaine~
ECS strikes again! 2007 STi Limited Swap, into my GC = ) NicFunkadelic Subaru Conversions 36 09-12-2007 03:32 PM
Andrewtech and TurboXS strike again! Built 30R Street Monster inside forgedSTi Proven Power Bragging 77 06-02-2007 05:39 PM
Stage II 05 STi 300 WHP/315 ftlbs krambte79 Proven Power Bragging 17 01-13-2007 11:32 PM
FS: '05 STi Partout! UR T3/T04S, Cobb AP, PE 850cc, AVC-R, Coolingmist, Defi! anthongy817 Engine/Power/Exhaust 25 11-07-2006 04:05 PM
FS AZ: 05 STi 470 whp many extras Zrex11 Private Vehicle 'For Sale' Classifieds 15 08-02-2006 03:48 AM
