Old 09-03-2007, 04:01 PM   #1
sfwrx
Member#: 88382
04 WRX
Question Size for Tranny drain plug and diff plug?
Does anyone happen to know what socket I need to get these plugs out to replace tranny fluid and diff's fluid? I'm not sure where to get the socket for the rear diff drain plug....thanks a lot.
sfwrx is offline   Reply With Quote
Old 09-03-2007, 07:18 PM   #2
rendog24
Member#: 125463
use a 1/2 inch rachet with no socket on it. it is square and should fit right in there.. on MY06+ the tranny is a torx socket so im not too sure about yours. i believe it is a 22mm , but dont quote me, do a quick search.
rendog24 is offline   Reply With Quote
Old 09-03-2007, 09:25 PM   #3
MrSlowbaru
Member#: 129231
2005 wrx
cgm
t-70 torx
MrSlowbaru is offline   Reply With Quote
Old 09-03-2007, 09:54 PM   #4
norexyet
Member#: 39149
11 elantra
yea i said elantra
rear diff is 1/2" ratchet.......trans is either a 22mm or a t-70 torx
norexyet is offline   Reply With Quote
Old 09-04-2007, 07:16 PM   #5
azscooby
Member#: 115297
2002 ej207 vf34
Be careful with using the 1/2" rachet, not all are created equal. Mine had rounded edges and I stripped the plug somewhat.
I had another ratchet that had better "squared off" edges, and worked much better.
azscooby is offline   Reply With Quote
Old 09-04-2007, 07:41 PM   #6
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
2004 also uses the torx as well, I bought mine off ebay for less than $20 shipped.
boundy3 is offline   Reply With Quote
Old 09-04-2007, 08:02 PM   #7
rendog24
Member#: 125463
i didnt know that....logged in my memory though for future reference...oh and if you cant get a hold of a t70, i just changed my tranny oil and a t60 worked just fine, thought i was gonna strip it but it fit "like a glove"
Old 09-05-2007, 12:45 AM   #8
sfwrx
Member#: 88382
04 WRX
Excellent! Thanks a lot guys!
Cheers,
Old 09-09-2007, 09:32 PM   #9
sfwrx
Member#: 88382
04 WRX
Question Color of Redline shock proof 75W90, and sizes
1. Does anyone know the color of Redline shockproof 75w90? I have it in my tranny and haven't checked. I looked at it today, and it looks like blueish-green color...i thought it was red.
2. I got 04 WRX. The rear diff nut isn't 1/2 inch rachet thing...can't use it. Also, I thought I could inspect the rear diff fluid, but don't see a place I can look through to see the oil level.
3. The drain plug for the tranny isn't the t-70 torx. Only a socket can be used...and it looks like 13/16 inch socket. isn't that 21mm?
4. A mechanic told me the tranny fluid doesn't need to be replaced (not for manual tranny)....really?
Old 09-15-2007, 11:37 AM   #10
irocznissan
Member#: 157638
1994 impreza
blue
1. lightweight shockproof is blue. heavyweight is red. 2. idk. 3. i think i used 15/16 or 7/8, 4. what moron told u that. lol
irocznissan is offline   Reply With Quote
Old 09-15-2007, 08:49 PM   #11
sfwrx
Member#: 88382
04 WRX
Thanks, Irocznissan.
haha....i feel better knowing it should be replaced now. yeah I was a little nervous seeing blue when I thought it was red. I put in Royal Purple and so far I like it. Shifting is a little less smooth....so I double clutch to make it smooth....no problem so far.
I got the tranny nut....it's 13/16.
Old 09-15-2007, 11:38 PM   #12
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Originally Posted by sfwrx View Post
1The rear diff nut isn't 1/2 inch rachet thing...can't use it. Also, I thought I could inspect the rear diff fluid, but don't see a place I can look through to see the oil level.
for the rear diff, there are two plugs - the upper one is the fill hole - to check the oil level, remove the plug and stick your finger in there - you are checking to make sure the oil level is even with the bottom of the hole. Removing the plugs (fill and drain) should be a 1/2" drive socket wrench or breaker bar... remove the fill plug first (because if you can't get it out, you don't want to be draining the differential), then the drain plug.
Gutted uppipe for sale with resistor and EGT plug... J. Steinbeck Engine/Power/Exhaust 14 06-24-2008 05:27 PM
FS: 2004 STi 6spd Swap Tranny, Axles, Shaft, and Diff Hubs too Tigre Tuning Drivetrain 20 06-18-2008 03:10 PM
Socket size for oil drain plug? Cusson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-09-2008 07:12 PM
Request: Torx T70 Bit for Tranny Drain Plug vtbandit Mid Atlantic Impreza Club -- MAIC 5 05-05-2006 11:16 AM
torque spec for tranny drain plug soobieajax325 Transmission (AT/MT) & Driveline 2 02-04-2006 04:41 PM
