Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 09-03-2007, 12:03 PM   #1
l0pl0p
Member#: 157588
2007 STI
Default Logging '07 STI with Enginuity and a VAGCOM cable
I recently purchased an '07 STI, and outside the standard lowspeed bucking and occasional "hesitation" (knock event?) issues everyone else is experiencing, it pulled like mad. Sometime around the time of my last fillup, it is now feeling very slow, mostly in >3rd gear on boost. I suspect bad fuel.
Coming from the Veedub world, I own a VAG-COM. This would sometimes occur in my VWs, and I'd log and find out massive amounts of timing were being pulled due to poor gasoline. My VWs were fairly picky about fuel--I assume some of the stations around me have ethanol in them, or perhaps poor mixing or additive packages.
I assume my STI doesn't like the fuel I put in last time, and I'd like to datalog it. I see the nice little app Enginuity that I could use. My question: can I use Enginuity with my VAG-COM HEX-USB +CAN cable (linked above)? Or do I need the oft-mentioned tactrix cable?
I have used my VAG-COM cable and software on other OBDII cars to pull/reset codes. I assume it will work, but I thought a quick query of the experts might be wise. TIA
l0pl0p is offline   Reply With Quote
Old 09-03-2007, 05:05 PM   #2
taank13
Member#: 86789
2008 Wrangler Unlimi
Rescue Green
I have been able to log using a vag-com cable and enginuity, however you can not use it with ecuflash to reflash, at least I havnt been able to.
taank13 is offline   Reply With Quote
Old 09-03-2007, 05:40 PM   #3
l0pl0p
Member#: 157588
2007 STI
Just what I needed to know, thanks!
Assuming I find my ECU pulling timing, and perhaps have a low IAM, how long will this take to go back to normal after finding fuel it likes?
Old 09-06-2007, 01:24 PM   #4
80884
Member#: 56783
2004 sti
Aspen white
I reflashed my 04 sti with a vag-com cable if that means anything. Actually, I've used it on a few other DBW suby's as well, 04's and 05's. The vag-com will not work on DBC subarus.
80884 is offline   Reply With Quote
Old 09-06-2007, 05:41 PM   #5
taank13
Member#: 86789
Rescue Green
hmm, what program did you use to flash with, i cannot get it to work with ecu flash. any ideas?
Old 09-06-2007, 09:12 PM   #6
l0pl0p
Member#: 157588
2007 STI
Thanks!! That's very helpful.
Old 09-07-2007, 08:46 AM   #7
80884
Member#: 56783
2004 sti
Aspen white
What is the car you are trying to flash? If it is a wrx with a cable throttle then the cable will not work. I have only been able to flash cars with drive by wire with the vag-com cable.
What does it do when you try to flash? does it give you errors? or does it just do nothing?
Old 09-07-2007, 06:05 PM   #8
taank13
Member#: 86789
Rescue Green
im trying to flash a 2006wrx. it does nothing, wont let me read, write, or test write to ecu. I get an error every time i open up ecuflash... "error loading FTD2XX.DLL" which i believe i read somewhere has to do with the driver for the tactrix cable.
Old 09-10-2007, 09:48 AM   #9
80884
Member#: 56783
2004 sti
Aspen white
Yep, vag-com and wrx's does not work. It will work on any drive by wire subaru but not drive by cable.
The vag-com was designed to work on drive by wire cars, audi/vw. For whatever reason it doesn't have the right stuff to work with cable driven cars like the wrx. Sorry, you need the right cable.
Old 09-10-2007, 04:45 PM   #10
taank13
Member#: 86789
Rescue Green
see i thought 06/07 wrxs were dbw
Old 09-10-2007, 06:06 PM   #11
80884
Member#: 56783
2004 sti
Aspen white
IDK if they are or not. haven't messed with one yet. if they are dbw than idk why the cable wouldn't work.
Old 09-10-2007, 06:18 PM   #12
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
80884, did you use ecuflash with the vag-com cable?
mickeyd2005 is offline   Reply With Quote
Old 09-10-2007, 06:39 PM   #13
taank13
Member#: 86789
Rescue Green
yea, the 06 wrx is dbw, i finally got the driver error to go away by copying the file and pasting in the system32 folder, but it still wont recognize my cable. tried logging with enginuity then just to make sure the cable was working and its worked with that for about 1min then lost connection so i dont know what the deal is now.
Old 09-10-2007, 08:41 PM   #14
80884
Member#: 56783
2004 sti
Aspen white
Yes I used ecuflash with the vag-com cable. It worked on 04 and 05 dbw cars, didn't try it on and 06 and it wouldn't work for cable driven throttle cars.
Old 09-11-2007, 08:41 AM   #15
l0pl0p
Member#: 157588
2007 STI
I have not been able to get my VAGCOM cable to work with Enginuity and my '07 STI.
I have been able to connect with the VAGCOM cable and VAGCOM software in OBDII mode, and do some basic OBDII logging. But Enginuity won't find the USB VAGCOM cable.
I will putter around with it this evening and see if I can get it to work.
Old 09-11-2007, 07:03 PM   #16
taank13
Member#: 86789
Rescue Green
i finally gave up and ordered the tactrix cable haha
Help With Enginuity And Lc1 Logging stretchedk7 Open Source Reflashes 3 09-23-2008 01:13 AM
'07 sti with compressor surge rxer311 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 02-27-2008 02:31 AM
Dougies Friend With Enginuity and Tactrix...(Haltom) haloseven Texas Impreza Club Forum -- TXIC 7 02-08-2008 10:15 AM
'07 STI with SR56, TMIC, Alchy Injection on pump with AP2 Dyno Flash Proven Power Bragging 46 01-05-2008 12:53 AM
'07 Limited with DP and Intake Pro Tune Dyno Flash Proven Power Bragging 10 08-23-2007 01:39 AM
