Old 09-04-2007, 11:34 AM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default How do you remove the oil cooler?
Taking a few block to the machine shop, but have never removed the oil cooler before. Do they just twist off?
Old 09-04-2007, 11:45 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Remove the filter and then unscrew that big hollow bolt in the middle of it
mick_the_ginge is offline   Reply With Quote
Old 09-05-2007, 07:01 PM   #3
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
its a 24mm or a 27mm deep socket, i forget which but that'll do the trick.
TROLL is offline   Reply With Quote
Old 09-06-2007, 03:12 AM   #4
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Deep 24mm for the factory cooler, and 27mm for the greddy sandwhich adapter
wrx_driver_2002 is offline   Reply With Quote
How do you remove the little black box in the trunk? just one blunt General Community 10 09-04-2003 01:38 PM
how do you remove the pin things holding the roof on? True06 Interior & Exterior Modification 1 04-22-2002 11:02 PM
How do you remove the top part around the vents/gauge hood? BongMan Interior & Exterior Modification 2 04-07-2002 01:50 PM
How do you remove the trim above the A/C-Stereo Dolphin Overton Interior & Exterior Modification 2 02-27-2002 11:08 PM
