Old 09-04-2007, 08:52 PM   #1
DausWRX
Member#: 134429
02 wrx
blu
Default 2.5 or 2.0
so iv spent some time looking for a new engine for my stock 2002 wrx and im unsure where to go. Im looking for a 2.5 block but i wouldnt mind goin with a 2.0 but heard i would need to change out the ecu or something like that with the 2.5....can someone plz help thanks
DausWRX is offline   Reply With Quote
Old 09-04-2007, 08:56 PM   #2
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
You dont have to change out the ECU unless you wanted to run AVCS heads. You can put a 2.5 Shortblock in but you will need some type of Engine Management and a custom tune.
I am running a 2.5L STi short block with my 2.0L WRX head with a custom tune.
P.S. do a search on 2.5L Short block, Hybrid and other keywords that would tie into your search, there are a lot of posts about doing the hybrid swap on here.
MindzeyeWRX02 is offline   Reply With Quote
Old 09-04-2007, 11:19 PM   #3
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Def need a tune, but the factory ECU will run it fine, but I wouldn't get on it too hard until you get that tune, lest you run lean and go boom.
Acostafan is offline   Reply With Quote
Old 09-05-2007, 12:41 AM   #4
DausWRX
Member#: 134429
02 wrx
blu
Thanks, What exactly are AVCS heads? i hear that every where but i dont know what it means exactly and also if i buy a 2.5 block with AVCS heads will i need a pro tune or if a buy an COBB AP unit will that work jus as well?
Old 09-05-2007, 02:27 AM   #5
WRB04
Member#: 153304
you will definetly need a protune and the cobb ap is a great investment. I just finished my sti short block swap into my wrx.
WRB04 is offline   Reply With Quote
Old 09-05-2007, 12:30 PM   #6
modaddict
Member#: 95840
sold to a good bud
awaiting next car
hey nooB. search in this forum for "hybrid". there's 200 posts a week on hybrid questions.....this is exactly what you're doing.
AVCS is variably cam timing. Your 2.0l doesn't have it. the 2.5l's do. Your 2.0l processor doesn't have the capability to run AVCS......So if you want to go 'all out' and buy a longblock STi engine, you will also need the engine wiring harness and processor. (lots of $$$$).
Either way, you need EM whether you want EcuTek, Cobb, Utec, Hydra, etc, and you will want to get dyno tuned. Or else you risk the chance of breaking those weak little cast pistons in the 2.5l you just put in.
modaddict is offline   Reply With Quote
Old 09-05-2007, 02:11 PM   #7
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
LOL. Yeah the whole hybrid, avcs thing is talked to death and a search with some skimming through threads will get you a lot of info.
You can do the AVCS and run the Hydra EMS on your 2.0L ECU. But hydra is $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Old 09-05-2007, 04:04 PM   #8
Acostafan
Member#: 67398
2002 Now with 100%
Don't mislead the guy by telling him his pistons are crap. The pistons in the STI are hypercast, stronger than cast, but weaker than forged. They are more than adequate for a modest hybrid build(say up to 300whp).
Old 09-06-2007, 01:02 AM   #9
modaddict
Member#: 95840
sold to a good bud
awaiting next car
"hypercast" vs. cast.....You're picking your nose and still getting a booger.
they both are BRITTLE as ****. They may hold up, they may not. it depends on the tuning in the processor. If he runs the stock 2.0l one, we'll be reading a thread from him with the title of "why does my hybrid smoke, eat oil, and run rough???????????????????????????"
Old 09-06-2007, 01:06 AM   #10
04caliwrx
Member#: 157842
2004 wrx
I would say 2.5 %100 yes. No replacement for displacement man you will get so much more out of it!
04caliwrx is offline   Reply With Quote
Old 09-06-2007, 09:48 AM   #11
Acostafan
Member#: 67398
2002 Now with 100%
I assure you it runs quite well on the stock 2.0 ECU. HOWEVER, I would NOT run it for long. You will need a tune. I know plenty of guys belting out good numbers on your so-called boogers and have many miles on their engines.
Recommendation needed: 2.5 or 2.0 WRX heads better for engine build? (NON-AVCS) dubya-R-ex Built Motor Discussion 15 03-29-2011 09:17 PM
wtb:fp green or blouch dom 2.5 or 3.0 Derek C NESIC Private Classifieds 0 04-01-2009 04:47 PM
WTB: 2.5 or 2.0 wrx heads. mvcsk8r NESIC Private Classifieds 0 03-12-2009 11:41 AM
Wtb Short Block 2.5 Or 2.0 twrxmess Private 'Wanted' Classifieds 6 02-09-2009 02:37 AM
help! which knock sensor 2.5 or 2.0? WRB04 Service & Maintenance 2 10-30-2007 02:20 PM
