Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 09-05-2007, 12:02 AM   #1
nxttruck2002
Member#: 90879
Default 2007 STI Stage 2 - Tuned by enginelogics.com
This car is tuned by Brad (silvialost) who is the tuner at EngineLogics in Houston. The owner of the car is Joe (mixmatch). I'm putting this up for him/me to see what you guys think. I believe stock STI's make around 220ish on this dyno.
-Omar
nxttruck2002 is offline   Reply With Quote
Old 09-05-2007, 12:08 AM   #2
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Very low boost... 14.5psi is the stock boost level! As a result of the low boost levels, the a/f ratio is on the lean side and I'm assuming timing is very aggressive to make the power that it does. This car is missing a ton of mid range torque and some peak power as well.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 09-05-2007, 09:21 AM   #3
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Ditto. Do you know why he chose not to up the boost at all?
crazymikie is offline   Reply With Quote
Old 09-05-2007, 09:34 AM   #4
mixmatch
Member#: 132057
2007 STi
Urban Gray Metallic
despite what the graph says, my boost gauge reads 17-18 psi at full boost
just a side question, what is best place to T into for boost gauge?
if i am missing power, could that help explain why i cant trap higher than 79mph in the 8th? my times havent been stellar by far but trap speed is dependent more on power than shifting right?...i usually top out 3rd in the 8th, i've also tried shifting to 4th a few car lengths before the trap to see if that helped as well but 80mph+ trap speeds have eluded me in my ~40 passes.
mixmatch is offline   Reply With Quote
Old 09-05-2007, 10:55 AM   #5
crazymikie
Member#: 56321
Green
I tee it into the small line on the side of the BOV. People use the FPR, but I think that's a bad idea in general since you really don't want to risk a leak there.
Trap speed is dependent on power, but if your launch and shifting isn't great, then your speed will suffer too.
Do you have an EGT gauge? What are they like?
Old 09-05-2007, 01:09 PM   #6
modaddict
Member#: 95840
sold to a good bud
awaiting next car
needs more boost.
your gauge is probably wrong.
modaddict is offline   Reply With Quote
Old 09-05-2007, 01:18 PM   #7
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
I was trapping 80-81 in the 1/8th stock before tune or exhaust. Stay in 3rd. What are your 60 ft times? You can pull low 1.7's stock. Wind out first gear to about 6500, and shift to third by 6000
TAPOUT is offline   Reply With Quote
Old 09-05-2007, 02:36 PM   #8
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
from my experience, ur aftermarket boost gauge will read higher than what the dyno set up does and i agree w/ modaddict.
prolly why ur only trapping no more than 79mph in the 1/8th.
what type of EM are u using to tune?
stickman is offline   Reply With Quote
Old 09-05-2007, 10:15 PM   #9
mixmatch
Member#: 132057
2007 STi
Urban Gray Metallic
using UTEC Delta. i currently have the boost guage Td off of the FPR so I will see about moving it.
I do have EGT but have not installed the sensor yet.
my best 60' has been 1.97, sucks i know, but ive been hesitant to rev it to 5k+ for launching until the last time i went to the track. hopefully its just a matter of time before i can get better...just need more practice.
Old 09-06-2007, 12:35 AM   #10
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
If you don't push it a little harder, you can hurt it more by bogging than getting a good launch.
Old 09-06-2007, 12:42 AM   #11
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Guys, if your not familiar with this dyno, don't say his car is lacking power, my car made 260whp and 233wtq on the same dyno, and was good for 12.5s @107+ summer time pump gas only. With some 1.7 60's and some aggressive shifting, that car will be good for low 12s...If you don't have a header on your car, definately get a set.
good job Brad!
Trey
treystoys is offline   Reply With Quote
Old 09-06-2007, 04:03 AM   #12
Farnk
Member#: 91093
2002 Wrx
Brad does good work.
Farnk is offline   Reply With Quote
Old 09-06-2007, 10:25 AM   #13
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
your logs said otherwise
bren wrx is offline   Reply With Quote
2006 WRX stage 2 tuned by TurboXS roccer Proven Power Bragging 2 05-22-2010 10:45 PM
2007 STI Stage 2 Re-Tune after fixed leak +13whp, +17ft-lbs! Equilibrium Tuning Proven Power Bragging 6 03-17-2010 06:41 PM
02 Stage 2 Tuned by Surgeline boostfeen51 Proven Power Bragging 16 05-11-2009 08:57 PM
Stage 2 Tuned by Andy @ Xotic Honest Bob Proven Power Bragging 7 11-21-2006 06:42 AM
06 STI Stage 2 Protuned by Chris at XX Tuning sodo Proven Power Bragging 38 06-15-2006 08:43 AM
