Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 09-05-2007, 03:00 PM   #1
rpm_nick
Member#: 117406
1999 2.5rs/wrx
Default compression ratio question
I am gathering the last parts of my build and would like opinions on CR. Here are the parts.
2.2 N/A block .020 over
USDM wrx heads
Wiseco 2.2l turbo pistons
2.2 rods and crank
rpm_nick is offline   Reply With Quote
Old 09-05-2007, 07:00 PM   #2
rustyzipper
Member#: 79175
2004 FXT
Red
8.5 or 9.1 , your choice, depends on what you want to do with it.
rustyzipper is offline   Reply With Quote
Old 09-06-2007, 12:04 AM   #3
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
There is a few CR calculator links in that thread. echo?
http://forums.nasioc.com/forums/show...hlight=genious
Kosmic is offline   Reply With Quote
Old 09-06-2007, 03:41 PM   #4
rpm_nick
Member#: 117406
1999 2.5rs/wrx
looking for reliability for a daily.
Old 09-06-2007, 03:51 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
which piston (need model number)? what headgasket (thickness and bore)? and how much are you decking the block?
all things that you need to know to figure out what CR you'll have.
Old 09-06-2007, 04:47 PM   #6
rpm_nick
Member#: 117406
1999 2.5rs/wrx
I know how to come up with the compression ratio. I am trying to decide on what to go for. All the machine work is done it is just down to figuring the head gasket to use and if I need to deck the block. I was leaning towards 8.5:1 for the CR. Just trying to get others opinions on the matter.
Old 09-06-2007, 04:55 PM   #7
R & H Garage
Member#: 139767
do you have water/alky injection? If so, I'd say 9:1
If not, I'd say 8.5:1
R & H Garage is offline   Reply With Quote
Old 09-07-2007, 01:37 PM   #8
rpm_nick
Member#: 117406
1999 2.5rs/wrx
Nope just building a "stock" setup for the most parts, nothing major done to it. From my calculations if I run the .030 cometic I will be sitting at 8.36:1. If I have clearance for the .027 it will up it to 8.41, just need to check valve clearances.
Old 09-08-2007, 12:24 AM   #9
hotrod
Member#: 14141
2002 Impreza WRX
you don't want to deck the block that jacks up your cam timing due to its effects on the cam drive belt length between the crank nose and the cams. It changes the cam timing more on one head than it does the other so it makes for problems you don't want to deal with.
There are a couple posts on this where folks ran into that problem.
There is a very small limit to acceptable change in head gasket thickness, and deck height, cylinder head milling must all fall within.
Larry
hotrod is offline   Reply With Quote
Old 09-09-2007, 01:14 AM   #10
Homemade WRX
Member#: 33782
96 bastard child
you can deck the block and head but make sure that you deck the right amount and use the right headgasket to offest the amount you removed and set you back to zero...then no cam timing gets affected
compression ratio question petawabit Built Motor Discussion 6 03-03-2006 10:26 PM
Compression ratio question. AlbanianImpreza Engine Management & Tuning 13 01-05-2005 02:32 PM
EJ22-T Swap - Compression Ratio Question Andursun0013 Subaru Conversions 4 03-03-2004 10:04 PM
Question about turbos and compression ratios. cRayZee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-04-2001 03:26 PM
Compression ratio question fellfrosch7 Normally Aspirated Powertrain 12 03-14-2001 12:43 AM
