South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-05-2007, 03:42 PM   #1
Black06TR
Scooby Scammer- Do Not Buy From User
Member#: 106323
2006 TR
Default Need DP installed...Help
where is the best place i can get my DP installed today??...
Black06TR is offline   Reply With Quote
Old 09-05-2007, 03:47 PM   #2
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
pm treefrog!
szeny is offline   Reply With Quote
Old 09-05-2007, 03:50 PM   #3
Black06TR
Member#: 106323
2006 TR
who is treefrog?...ill try contacting him
Old 09-05-2007, 03:54 PM   #4
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
treefrogaz..works for RPM
Old 09-05-2007, 03:55 PM   #5
r0bman
Member#: 87015
One of the easiest things you can do... you need a 14mm & 15mm box & socket, a rachet, and jack stands... and a socket for whatever size the turbo heat shield bolts are (9mm?). Oh, and WD40 and new turbo-side and doughnut gaskets. Takes about an hour....
r0bman is offline   Reply With Quote
Old 09-05-2007, 04:18 PM   #6
ghibli99
Member#: 90761
2003 S2000
Save the Manuals!
Yep, what he said. PB Blaster tends to work a little better for the bolts. Don't forget something for the O2 sensor... you don't need an O2 socket, and a wrench works fine. You don't need new gaskets, either... the donut at your DP/IP can be reused, and I've reused my turbo/DP gasket after two turbo swaps w/ no leaks (YMMV). After you do the install and drive it around a little bit, recheck the nuts/bolts at the turbo/DP... they might be a little loose. The key is to take your time with the bolts/nuts. I've seen so many people try to rush this or not take the time to soak 'em, and they end up either breaking or seizing them.
-Mike
ghibli99 is offline   Reply With Quote
Old 09-05-2007, 04:50 PM   #7
r0bman
Member#: 87015
Oh yeah, forgot about the O2 sensor.
*looks at huge scar on knuckle
... do NOT use an adjustable wrench
Old 09-05-2007, 05:00 PM   #8
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
I'm sure you can. Just wear gloves when you do it. Hands saved.
Black-Falcon is offline   Reply With Quote
Old 09-05-2007, 05:02 PM   #9
r0bman
Member#: 87015
Nah, that'd be too smart
It was actually putting my old WRX back to stock. I usually put the O2 sensor in before strapping the pipe back into the exhaust, but I forgot, and had already put everything back together. So I was trying to do it under the car, my hand slipped and I rounded the sensor bolt a bit, and punched the crap out of the heat shield. Good God did that hurt. Took forever to get all the grease / grime out of the cut, too.
Old 09-05-2007, 05:43 PM   #10
ghibli99
Member#: 90761
2003 S2000
Save the Manuals!
Ack... my knuckles hurt just reading that!
-Mike
Old 09-05-2007, 06:18 PM   #11
incuhed
Member#: 137008
2005 9-2x
red dragon
if you've never installed parts on your car, then this is not the easiest thing to do, but with a couple weeks on and off researching what you need and what steps to take, should be doable. Depends if it's worth your time to learn and possibly buy or borrow tools. And cutting that turbo heatshield.....
incuhed is offline   Reply With Quote
Old 09-05-2007, 06:21 PM   #12
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
scooby mods?
MrMcCrackin is offline   Reply With Quote
Old 09-05-2007, 07:28 PM   #13
wagonmasta
Member#: 52880
GGA Rev.D
whats up with this????/
Black06TR
Scooby Scammer!!!
Member#: 106323
2006 TR
wagonmasta is offline   Reply With Quote
Old 09-05-2007, 07:39 PM   #14
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
STi Wamper
MAN LOVER!!!
Member#: 52880
GGA Rev. D
<------R3V0 KCUF 3HT 3V0M
Old 09-05-2007, 07:49 PM   #15
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
yikes - *runz and hides*
Old 09-05-2007, 08:17 PM   #16
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
wtf??????
06AZREX is offline   Reply With Quote
Old 09-05-2007, 08:26 PM   #17
wagonmasta
Member#: 52880
GGA Rev.D
oooo.... szeny.... you gonna get it boi....
just you wait henry higgins....
Old 09-05-2007, 08:36 PM   #18
wagonmasta
Member#: 52880
GGA Rev.D
szeny
Ku Klux Klan Grand Wizard
Member#: 81383
2005 STi
it has a tow hitch for rope
Old 09-05-2007, 08:46 PM   #19
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
lolz no guard for the win!
Old 09-05-2007, 08:50 PM   #20
ghibli99
Member#: 90761
2003 S2000
Save the Manuals!
Black06TR
Scooby Scammer!!!
Member#: 106323
2006 TR
http://forums.nasioc.com/forums/show....php?t=1232498
Ruh roh.
-Mike
Old 09-05-2007, 08:59 PM   #21
wagonmasta
Member#: 52880
GGA Rev.D
bingo bango....
where'd ya go buddy?
Old 09-05-2007, 09:28 PM   #22
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
well - wtf happened yo?
Old 09-05-2007, 09:33 PM   #23
wagonmasta
Member#: 52880
GGA Rev.D
he's not online......
yet another thread to go OT
this guy is 27 ???? look at all the threads he's started
Old 09-05-2007, 09:38 PM   #24
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Tuned @ FAT by Snail Perf
uber pwnage...
BugeyePB Rex is offline   Reply With Quote
Old 09-05-2007, 10:24 PM   #25
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!Scooby Scammer!!!
VF52 ad DP install help needed Sumbata Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-16-2009 04:20 PM
UP/DP install help in NH eb50 New England Impreza Club Forum -- NESIC 20 09-26-2006 03:45 PM
Burlington, VT area UP/DP install help maxitout77 New England Impreza Club Forum -- NESIC 4 01-21-2006 04:16 PM
Need dp installed Sat. Ft Worth/ Arlington area sleestak6326 Texas Impreza Club Forum -- TXIC 1 01-11-2006 09:23 AM
SE MI: DP Installation help!??!!??! Alpinestar Mid West Subaru Owners Club Forum -- MWSOC 2 11-11-2005 01:02 AM
