Old 01-10-2002, 08:37 PM   #1
Blue02WRX
Member#: 5841
Default How bad is it to leave out the exhaust manifold heat shields?
i am in the process of changing my uppipe, tomorrow is put everything back on(i ran out of daylight. right now i can put the heat shields back on, but do i have to??? what are the cons of this procedure? is there something that i have overlooked as to why they NEED to go back on? thanks, Brian Matta
Blue02WRX is offline   Reply With Quote
Old 01-10-2002, 09:09 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Just be careful not to drip any oil on the unshielded exhaust manifolds. Those cast iron suckers get HOT. Good way to start an engine fire.
The SS of the up-pipe keeps it significantly cooler, but I'd at least think about putting the shielding back on the manifolds.
Concillian is offline   Reply With Quote
Old 01-10-2002, 09:09 PM   #3
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
basically you don't really need to since there won't be a cat there which is what really heats things up in the first place. SUS has pretty good heat rejection properties.
ellisnc is offline   Reply With Quote
Old 01-10-2002, 09:26 PM   #4
slin02
Member#: 11588
I chanegd my uppipe a while ago ( haha have fun ) and I have been lazy enough to put bak any heat shells that I have removed ( excpet the turbo ones) and my car is running just fine. just to share with you. oh if u decided not putting back heat shells, make sure you cover the holes on the headers. ( or your car will be smoking out front! )
good luck !
slin02 is offline   Reply With Quote
Old 01-10-2002, 11:30 PM   #5
TurboRex
Member#: 8635
04 STI, 07 FXT
I took all mine off and left it that way. It is easier to work on it in the future. I can't believe it would matter. The exhaust is more exposed and could heat up surrounding hardware but with the uppipe out and all I figure we should be okay.
I hope so anyway.
Greg
TurboRex is offline   Reply With Quote
How bad is it to flog on the car when it's still cold. Hyelude Newbies & FAQs 24 10-22-2008 01:09 AM
how hard is it to change out the intake manifold? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-31-2005 11:45 PM
How bad is it to hold down the clutch? GC84ever Transmission (AT/MT) & Driveline 5 09-20-2004 09:58 PM
How bad is it to move with the parking brake?? mike270 Normally Aspirated Powertrain 2 09-15-2002 12:19 AM
How hard is it to take out the factory manifold? Code-7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-30-2002 09:42 AM
