Old 09-06-2007, 01:35 AM   #1
mm88swrt
Member#: 138771
1987 gl-10 turbo
factory silver
Question 99 2.5 rs suspension and motor swap, into 97 impreza s/w??
i've got a 99 2.5 rs that was wrecked. i'm wanting to put the full suspension, motor, tranny, wireing harness and such into a 97 impreza sport wagon. my question is will there be any sticky situations i need to know about or will it all bolt in with just a lot of work? thanks guys
mm88swrt is offline   Reply With Quote
Old 09-07-2007, 04:17 AM   #2
AllWheelsDriven.net
Vendor
Member#: 124802
1996 22B-righton STi
Graphite Grey
It's pretty straightforward really.
Swap all of the running gear from the RS (eng, trans, driveline, diff) into the wagon. Make sure the headgaskets are good, or else replace them before your swap. You'll save yourself a headache.. All 2.5 N/A headgaskets are prone to failure. Might as well swap the brakes from the RS too..
Keep the 2.5 engine, intake manifold, wiring attached. Your chassis harness _should_ plug into the RS engine harness. Check the big square plugs to see if they look the same. Should be 2 of them attached to the trans/or near it. Replace the 2.2 ecu with the 2.5 ecu. Fire it up!
Is your wagon 5mt or AT?
Hope this helps..or lmk if you have any other questions.
Barrett-
www.allwheelsdriven.net
AllWheelsDriven.net is offline   Reply With Quote
Old 09-07-2007, 08:52 AM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Chassis harness will definitely not plug into the engine harness. Wiring will be the toughest part of this swap; honestly it might be worth selling the engine and finding a 98 2.5, which is plug and play.
jamesfacts is offline   Reply With Quote
Old 09-08-2007, 08:24 AM   #4
Member#: 158703
2001 VF34'd RS
BRP
james is right.
or, doing an engine harness swap might be your best option.
ryan@area1320 is offline   Reply With Quote
Old 09-10-2007, 02:17 AM   #5
mm88swrt
Member#: 138771
1987 gl-10 turbo
factory silver
i'm probly going to swap all harnesses while i've got everything out. engine and under dash. thanks for all the help. wish me luck!!
Old 09-10-2007, 11:31 AM   #6
jamesfacts
Member#: 51282
98 RS
Unless you're planning to make a 2 door OBS that's not going to work.
99 2.5 Rs Suspension swap. kamilrs Normally Aspirated Powertrain 8 10-09-2008 11:13 PM
04 2.5 Forester motor in a 99 2.5 RS? R.B. WRX Wagon Subaru Conversions 3 08-24-2007 05:21 PM
97-99 2.5 RS CAI on 97 2.2 L spinmastert Normally Aspirated Powertrain 6 08-19-2005 11:59 PM
02 Wrx Swap Into A 99 2.5 Rs What Cani Use What Cant I GODSON Subaru Conversions 10 10-12-2004 03:56 PM
FS: 99 2.5 RS suspension mav1c Private 'For Sale' Classifieds 5 08-21-2003 09:57 AM
