09-06-2007, 04:29 AM | #1 |
Member#: 104315
SWIC
Vehicle:03 sti conversion to be announced..... |
new set up
its is perrin filter from short ram ,perrin fmic, sti pinks, fp18g 7cm ,ecuteck ,walboro fuel pump ,tgv delete by forced air, ra gears helix suspension , invidia up and down pipe, agency power exhaust ,kart boy shifter,knob,and bushings,and jdm hood scoop,exedy stage one clutch ,act street light flywheel
all for 03 bug eye but the ****tty part is got tuned at dyno comp and he could only get 14lbs of boost out of it and it was 262whp so i orddered a new 14lb actuator he said it was only a 8lb for the waste gate and he thinks it should be around 30more whp
09-06-2007, 10:03 AM | #2 |
Member#: 89202
SWIC
Vehicle:I'm # 1 when it comes to # 2 |
yikes - what is the 18g rated for?
09-06-2007, 10:21 AM | #3 |
Member#: 136438
SWIC
Vehicle:RIP: 2004 WRX STi WRB/G, 322whp/330wtq |
Nice set up, good numbers good luck with the bigger actuator.
09-06-2007, 12:12 PM | #4 |
Member#: 98960
SWIC
Vehicle:1978 brat (fo realz) red |
definitely should have been able to get more power out of that setup. maybe in new of an upgraded boost control solenoid.
09-06-2007, 01:57 PM | #5 |
Member#: 63605
SWIC
Vehicle:04 Wrx Wgn TimeAtk 10 Golf TDI, 08 Stang GT |
yeah pick up a prodrive wg solenoid. i had issues with my stock one, once i went to the 18g. car didn't want to put out, now it has no issues running 23 psi. i made 335whp on 100 octane with the 18g, with rich tuning it
09-06-2007, 02:25 PM | #6 |
Member#: 104315
SWIC
prodrivce boost solenoid
are they hard to put in
09-06-2007, 02:30 PM | #7 |
Member#: 98960
SWIC
plug and play dude
09-06-2007, 08:04 PM | #8 |
Member#: 116437
SWIC
i want one myself
09-07-2007, 08:28 AM | #9 |
Member#: 104315
SWIC
boost solenoid
k so i am gonna gt the 14 lb avtuator then get it tuned and then if tht dont work i wil det the actuator
09-07-2007, 02:24 PM | #10 |
Member#: 98960
SWIC
i think the other way around will be the cheaper route.
09-07-2007, 06:35 PM | #11 |
Member#: 104315
SWIC
boost actuator
k well fp is sending it to me for free and then rich will tune then if not work then i will get the boost solenoid
09-07-2007, 06:41 PM | #12 |
Member#: 63605
SWIC
i went thru the same thing. talked to blouch, they said sending me an actuator would be a waste of time and to get a new wg solenoid. solenoid works, stock one tends to bleed off too much.
09-07-2007, 10:37 PM | #13 |
Member#: 98960
SWIC
if they are sending it free then go for it but i still dont think its going to make much of a difference. will just start to bleed boost later. you still wont be hitting good boost targets
09-07-2007, 10:38 PM | #14 |
Member#: 98960
SWIC
btw....... imho you should still get the prodrive before you have rich tune it. almost 100***37; you are gonna need it and that way you wont have to pay rich to tune your car again later.
My new set up (Pictures inside-56k be aware) | ScoobyNewbie101 | Car Audio, Video & Security | 13 | 07-18-2005 12:08 PM |
Guessing new set up power!!! | DuoMaxwell | Subaru Conversions | 7 | 09-17-2004 02:08 PM |
1st Auto-X on new set-up | Georgethefierce | Brakes, Steering & Suspension | 3 | 07-28-2004 05:41 PM |
Question about my new set-up | Ft_Laud_wrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 11-14-2003 12:13 AM |
My new set-up (on order) | Basshead | North West Impreza Club Forum -- NWIC | 0 | 03-17-2000 08:15 PM |
