Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 01-10-2002, 10:12 PM   #1
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Default Using E-Brake for launch?
Iv got this video of an STI WRX in japan doing an e-brake launch on a manual.
Pretty much, he pulled the e-brake and used it to hold the car while he put out the clutch a little and added gas to prevent a stall. He held it right at 2k, and to launch he just slammed the e-brake down and did a perfect launch (no tire burn or 5k clutch drop) ran a 13.6 stock too
SO.....with all that, how bad is using the e-brake to hold th car in place on the center diffy? I know its not the best on the clutch, but will I kill my center differential by using it?
DDMan is offline   Reply With Quote
Old 01-10-2002, 10:45 PM   #2
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I didn't know the e-brake was that strong.
Mine barely keeps the car from moving at idle in 1st or reverse. Barely.
remarcable is offline   Reply With Quote
Old 01-11-2002, 01:35 AM   #3
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Thumbs up I do that!
That's what I do at the drags and auto-x. Pull the e-brake so I don't roll forward or backwards, rev till about 4-5k and slowly let the clutch out until I feel it BARELY grab. Yes, its hard on the clutch, yes, I know I'm "burning" the clutch, but as soon as I see the yellow lights I drop the e-brake, release the clutch and squeeze the gas. It's my patented stinky-clutch launch - only used at the track. It's allowed me to beat a supercharged Formula Firebird to 60 ft! And that was carring another passenger too! Of course I lost the race. You didn't expect me to win down the 1/4 mi against that thing did ya?
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 01-11-2002, 02:26 AM   #4
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
can you post a link to the vid, if it's on the net somewhere.
garface is offline   Reply With Quote
Old 01-11-2002, 09:13 AM   #5
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
Actually he was using a lever to adjust his centre diff. If you look closely in the video there is still an e-brake there. I don't see any value in using the ebrake to launch as it's not strong enough and won't really do anything for you.
-Michael
d00f is offline   Reply With Quote
Old 01-11-2002, 09:44 AM   #6
DDMan
Member#: 11221
2002 2.5 RS
ill post the video a little later, and mine is REALLY strong then. cuz I can EASILY stall the car keeping it at 2k and letting the clutch out too much (did it accidentally).
Old 01-11-2002, 09:46 AM   #7
DDMan
Member#: 11221
2002 2.5 RS
Heres the link....hopefully iy will work, and its 3.25 meg
ftp://ftp:ftp@63.78.32.32/toyota_mr2...ru_wrx_(1).avi
right click then go to "save as"
cant watch it on the net
Old 01-11-2002, 11:07 AM   #8
FargoRS
Member#: 419
Wouldn't using E-brake help build Boost since the engine is under load Guess I should try it today
Mike
FargoRS is offline   Reply With Quote
Old 01-11-2002, 01:35 PM   #9
Penphoe
Member#: 269
-Michael
Well, I use the e-brake to hold my car in place. I'm limiting the amount of power that goes to the ground through my clutch because I'm allowing it to slip.
You're right, the e-brake is not strong enough to hold a car from moving given enough power - I'm limiting the power going to the ground.
LaterZ!
Darren!!
Old 01-11-2002, 02:59 PM   #10
garface
Member#: 1581
MY00 RS/STi7
Can't download it right now, but is that the one with the white Rex going against an MR2 and the driver starts laughing after seeing his lead?
Old 01-11-2002, 07:40 PM   #11
Penphoe
Member#: 269
Yup! That's the one. Gotta love that dude's laugh eh?
LaterZ!
Darren!!
Old 01-12-2002, 12:17 PM   #12
d00f
Member#: 6000
BRP
That seems to me like an expensive way to fry your clutch and take 0.01 off your trap time. Bearing in mind you can afford to roll forward about 5cm after being staged I doubt this is going to give you any improvement.
What you really need is launch control. It lets you hold the car at 1/2 throttle while selectively misfiring cylinders (not like antilag) in order to build boost under no engine load. It sounds really nasty but imagine having 8-10 PSI of boost when the tree goes green.
From what I can tell this doesn't beat your turbo to pieces like ALS because it's not backfiring, it's just not firing the injectors on some cylinders and in effect just pumping air through to spool the turbo. Spitting flames at the staging area would still be cool with true ALS
-Michael
Old 02-09-2004, 11:07 AM   #13
Turb0flat4
Member#: 53735
2003 Bugeye WRX
Default I use the same method
Hey there, I know this is late in this thread, but I just stumbled on it when I did a search for "launching with ebrake". I use the same method on the drag strip with good success, never bog the launch, unlike when I use just the gas and the clutch. I'm just wondering, like the orig poster, whether this will be hard on the center diff. I would guess not, because the clutch won't be fully engaged when the ebrake is on, but I'd like a definitive answer. Thank you.
Turb0flat4 is offline   Reply With Quote
Old 02-09-2004, 11:53 AM   #14
zumnwrx
Member#: 26792
03 wrx sedan
white
me too... ha ha good thread.
edgar,
zumnwrx is offline   Reply With Quote
Old 02-10-2004, 02:00 AM   #15
KoneKiller
Member#: 39191
2004 WRX STi WRB
Red 1990 Spec Miata
It will be hard on everything! Clutch, diff, geabox, CV's, axles, ebrake...
So what if you break stuff... that's what money is for!! I mean come on... it's JUST a car!
KoneKiller is offline   Reply With Quote
Brake tq launch in an 09 4eat TonyG Transmission (AT/MT) & Driveline 11 04-24-2010 11:34 PM
Brake Torqued launched then eBrake light came on? Unknown_Driver Brakes, Steering & Suspension 2 11-05-2006 05:59 AM
Brake torque launches with a 4EAT.. KillerRex Transmission (AT/MT) & Driveline 5 08-27-2002 09:18 AM
Brake Torquing Launches/Vacuuming Question RobPA Transmission (AT/MT) & Driveline 17 05-06-2002 07:06 PM
