Old 09-06-2007, 11:13 AM   #1
JamiePasson
Member#: 33909
Default Intermittent starting issues
I have a '96 Legacy 2.2 and it is starting to give intermittent starting problems. They are starting to increase in frequency though. The car will just crank. No start. I pulled a plug wire off the central coil pack and there was no spark. If you crank for a LONG time, it has always eventually started. No hiccuping or anything like that. When it eventually does start, it runs fine. Now, does that mean a coil pack or some other electronic issue? Has anyone experienced a similar problem? Also, I have a '95 Legacy 2.2 and that car has done it once also. Can anyone shed any light onto this?
Thanks,
Jamie
JamiePasson is offline   Reply With Quote
Old 09-06-2007, 03:50 PM   #2
spdracr00
Member#: 65823
1996 Impreza L
Red
well, start in all the normal places.
plugs
plug wires
coil pack
battery
grounds
my 92 2.2l was doing this and i found that my battery cable looked fine from the outside but the inside was all jacked up. all green and full of gunk.
spdracr00 is offline   Reply With Quote
Old 09-06-2007, 09:06 PM   #3
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
Sounds like the crank angle sensor. I had the same problem on my old 1995 1.8L Impreza sedan. This was a few years ago and the car had less than 30k miles, but I've heard of it being a problem on numerous Impreza and Legacy models from 1994-1997. I bought the car second hand, but I had the exact same symptoms. I think the part retails for about $70.
Hope this helps.
Matt is offline   Reply With Quote
(Halp!) Engine cutout & dies intermittently along with hot start issue DinoGuan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-30-2010 06:30 PM
Intermittent starting trouble during winter months. mikeybo Normally Aspirated Powertrain 1 06-23-2008 11:57 PM
intermittent starting issue JamiePasson Service & Maintenance 0 09-06-2007 11:50 AM
95' impreza intermittent starting problem Outback98 Normally Aspirated Powertrain 0 10-14-2005 10:37 AM
WRX manual cold start issue ort5 Transmission (AT/MT) & Driveline 10 12-17-2001 03:54 PM
