Old 09-06-2007, 11:50 AM   #1
JamiePasson
Member#: 33909
Default intermittent starting issue
I have a '96 Legacy 2.2 and it is starting to give intermittent starting problems. They are starting to increase in frequency though. The car will just crank. No start. I pulled a plug wire off the central coil pack and there was no spark. If you crank for a LONG time, it has always eventually started. No hiccuping or anything like that. When it eventually does start, it runs fine. Now, does that mean a coil pack or some other electronic issue? Has anyone experienced a similar problem? Also, I have a '95 Legacy 2.2 and that car has done it once also. Can anyone shed any light onto this?
Thanks,
Jamie
JamiePasson is offline   Reply With Quote
(Halp!) Engine cutout & dies intermittently along with hot start issue DinoGuan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-30-2010 06:30 PM
Intermittent starting trouble during winter months. mikeybo Normally Aspirated Powertrain 1 06-23-2008 11:57 PM
Intermittent starting issues JamiePasson Legacy Forum 2 09-06-2007 09:06 PM
95' impreza intermittent starting problem Outback98 Normally Aspirated Powertrain 0 10-14-2005 10:37 AM
WRX manual cold start issue ort5 Transmission (AT/MT) & Driveline 10 12-17-2001 03:54 PM
