Old 01-10-2002, 11:43 PM   #1
JNaubur
Member#: 4366
2002 Impreza 2.5 TS
Midnight Black Pearl
Default What is the oil pressure level?
I am going to install a oil pressure gauge from VDO. They have 2 different senders one for up to 80 psi and one for up to 150 psi.
My question is how much pressure does the oil get up to?
The gauges come in three different varieties, with scales up to 80/100/150. So I would like to get the closest one possible.
TIA,
JNaubur
JNaubur is offline   Reply With Quote
Old 01-11-2002, 01:46 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Get the 150psi on both counts. You will likely see oil pressures above 100psi in a Subaru engine.
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 01-11-2002, 09:54 AM   #3
JNaubur
Member#: 4366
2002 Impreza 2.5 TS
Thanks.
What should the oil pressure at 700 rpm idle be? nicholam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-31-2008 03:18 AM
What is EJ22T oil pressure? TyranosaurusWRX Subaru Conversions 9 05-11-2005 03:15 AM
What is the oil pressure psi on the sti's? StiGoddess Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-08-2004 09:22 AM
What is the premium octane level in Vegas? 2003 sedan South West Impreza Club Forum -- SWIC 4 05-01-2004 01:29 AM
What should the oil pressure be at idle? dlowman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-09-2003 04:02 PM
