Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 09-06-2007, 05:57 PM   #1
bugeyes
Member#: 64494
2001 V7 sti
Default Anyone running a true drysump setup with remote oil tank?
I have been looking into running a custom sump pan with a peterson 3 stage drysump pump, remote external oil tank.
I would then modify the original oil pump so it has no internals and use it only as a cover for the front of the engine (after blocking the respective oil passages).
I am thinking this setup will resolve a few issues-
1/ No chance of aerated oil getting into the oil supply
2/ Increased engine sump vacuum level
3/ Increasd engine overall oil volume
4/ Ability to better control and alter oil pressure
5/ Reduced sump pan size allowing for custom short length headers
6/ Overall improved reliability of engine oil supply at high rpms and cornering.
7/ Relocate oil filter to allow more room for headers (and easier changing access)
My only concern over this setup is the reliability of the pump drive belt which would be a HTD type (same type as timing belt but smaller). I wouldn want to have the belt fail or need to change it every 5000kms.
I would like some feedback from other people that may be already doing this.
Anyone out there ?
bugeyes is offline   Reply With Quote
Old 09-06-2007, 11:37 PM   #2
modaddict
Member#: 95840
sold to a good bud
awaiting next car
read through the whole thread! with pics!
http://forums.nasioc.com/forums/show....php?t=1272571
modaddict is offline   Reply With Quote
Anyone running a GD master cylinder with a GC single stage booster? AKGC8 Subaru Conversions 0 02-24-2009 02:38 PM
Anyone running a true dual fuel setup ? bugeyes Water/Methanol Injection, Nitrous & Intercooler Cooling 4 10-21-2008 10:33 AM
Anyone running an AMR T-60 with the AMR TMIC? L-SCHLEGS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-25-2008 02:08 PM
Anyone running a V7 short block with USDM STI heads? Trevor723 Built Motor Discussion 3 06-26-2007 09:48 PM
Anyone running a CObb stg 2 with an intake? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-10-2003 01:05 PM
