South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-06-2007, 09:42 PM   #1
IDAFC21
Member#: 60471
2004 GTO
QSM
Default just got my registration renewel
....and i need to be emission tested. noes!
IDAFC21 is offline   Reply With Quote
Old 09-06-2007, 10:10 PM   #2
enigma94
Member#: 143254
2007 STi
UGM
Time to try and find a buddy who lives out of the city, or has a cabin up north, thats how I register my civic. No emissions wooohoo!
enigma94 is offline   Reply With Quote
Old 09-06-2007, 10:16 PM   #3
IDAFC21
Member#: 60471
2004 GTO
QSM
i SHOULD be alright. as long as they just plug in their little scanner...and ignore my exhaust
Old 09-07-2007, 12:24 AM   #4
shemoves
Member#: 80663
2005 STi
Subarus get the OBD, visual, and the idle sniff test, but not run on the dyno. Do not let them run the car on the dyno.
If you are catless, you will likely fail the visual, but would prolly still pass the idle sniff (assuming the car isn't modded crazy and is running right).
shemoves is offline   Reply With Quote
Old 09-07-2007, 02:47 AM   #5
enigma94
Member#: 143254
2007 STi
UGM
hahaha yea, last time i was at the emissions place they tried to dyno a old vw bug with the front wheels on the rollers
They're definately not the brightest bunch of people....
Old 09-07-2007, 12:16 PM   #6
borkjam
Member#: 56774
2002 WRX Sedan
I was there with my 02 WRX a couple 2 weeks ago. All they did was plug in the OBD2 and inspect the gas cap. No visual, no popping the hood, nothing.
Makes me glad I didn't bother with swapping out the TBE and ECU.
They didn't even try to put my car on the rollers.
borkjam is offline   Reply With Quote
Old 09-07-2007, 03:24 PM   #7
Silver Ra
Member#: 123143
03 wrx 08 forester
98civic k24/k20 02 Rsx
i need a homie that i can payoff .!!>!
Silver Ra is offline   Reply With Quote
Old 09-07-2007, 03:40 PM   #8
#522
Member#: 2185
The visual test varies a lot. Sometimes they look, sometimes they don't.
My Subaru (01RS) just got the gas cap test and OBD2. Technically, if everything is working and your car is meeting emissions standards, your OBD2 should show no CELs and should be in a state of readiness. Even with a high flow, or other exhaust mods.
#522 is offline   Reply With Quote
Old 09-07-2007, 03:48 PM   #9
gringocl
Member#: 131728
MY02 RA Wagon
White (F.A.T.)
I got mine done 2 months ago, no visual just ODB2 and the gas cap....
gringocl is offline   Reply With Quote
Old 09-07-2007, 05:54 PM   #10
05BluePearlGT
Member#: 111760
1993 Impreza L
Java Black Pearl
My 93 got the hood popped, mirrors under the car to check for leaks/cats, and idle sniffer. I told them they better not put it on the 2wd emissions dyno thing and they didnt, lol. I passed, even with white smoke from oil dripping onto my exhaust, pouring out of the engine bay. It was all smokey in their work area, haha
05BluePearlGT is offline   Reply With Quote
Old 09-07-2007, 07:26 PM   #11
dozer54321
Member#: 116437
i took my 02 in january for emissions, no visual, again completely catless passed in 5 minutes, including line time
dozer54321 is offline   Reply With Quote
Old 09-07-2007, 08:32 PM   #12
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
OBD I vehicles still get the sniffer test, OBD II just get a scanner plugged into the port.
OBD II (mandatory in 1996) was designed to "on board diagnose" specifically emission problems. It's the governments way of controlling our cars, as the OBD system would give a check engine light if one of the systems was not working properly. That's why you can have intermittent sensor problems not show up in OBDII, god forbid it actually tells you about something that is hurting your performance. BUT, the instant your car puts out too much emissions, BAM!!, your car powers down.
OBD II does have it's advantages though. You could be running a 1,000 hp spitting flames out the back, but as long as your check engine light is off and the OBD returns no problems, you pass.
bobturismo is offline   Reply With Quote
Old 09-08-2007, 12:08 AM   #13
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Last time I took my swap through emissions the guy had me pop the hood and about a minute later he finally asked "is this 4 or 6 cylinders?"
He had ZERO clue what he was looking at.
AaronB is offline   Reply With Quote
Old 09-10-2007, 12:05 AM   #14
steverwrx
Member#: 24193
2002 WRX Sedan
I just had to get tested this past weekend. I just have the 3rd cat. No visual. They did rev the motor up a few times. Passed. Love OBD2!
steverwrx is offline   Reply With Quote
Old 09-10-2007, 03:57 AM   #15
pajak
Member#: 95992
08 E92 335i
Grey
got mine done 2 months ago put stock exhaust on but they never even looked just gas cap and scanner.
pajak is offline   Reply With Quote
Old 09-10-2007, 10:22 AM   #16
jamesnobrakes
Member#: 140999
2004 WRX Wagon
I wonder if it would help to flash economy or valet mode on the AP?
jamesnobrakes is offline   Reply With Quote
Old 09-10-2007, 10:59 AM   #17
r0bman
Member#: 87015
Nah. OBDII will return basically the same results. If you've got an AP map loaded, you're good to go as long as you don't get an ass that does a visual and sees you're missing cats. No check engine light = woot.
At least, that's how it worked in VA...
r0bman is offline   Reply With Quote
Old 09-10-2007, 11:50 AM   #18
racingfish
Member#: 60976
1969 LGT
FATURBO
Your also allowed 1 ready light.
racingfish is offline   Reply With Quote
Just got my 06 STi.. Just had my first accident ever. *pics* Drive_STIck General Community 50 06-20-2007 06:35 PM
My credit score finally got better, and I just got my pre-approval letter The Tree Off-Topic 32 05-11-2005 03:35 PM
Just got my Registration Renewal skinart76 Southern California Impreza Club Forum -- SCIC 54 12-04-2003 01:31 AM
Just got my registration renewal notice..... Project Jennifer Southern California Impreza Club Forum -- SCIC 21 10-29-2003 03:48 PM
Just got my VF30, got questions dandbest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-02-2002 10:14 PM
