Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 09-07-2007, 11:18 PM   #1
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Default WRX control arms on a BE...hmm
So I've been reading this:
http://scoobymods.com/forums/showthr...1280#post21280
And got to thinking...pick up some wrx sedan control arm takeoffs, change out the bushings (the front is $46 and the rears will be group N ones I bought from ten80 ), and the front track has just been increased by 20mm for under $200 and increased negative camber from the geometry change.
How would that affect the handling do you guys think? It should help reduce understeer and better turnin and sharper steering response (combination of the stiffer bushings, neg camber, and wider track)...at least that's what I'm theorizing.
I'm also thinking that the negative camber should prevent any rubbing from the fender with the wider track too...but it may be anyone's guess.
Right now I'm just bouncing this idea around. Opinions, questions, theories?
rougeben83 is offline   Reply With Quote
Old 09-10-2007, 03:16 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Well, I think I'm going to try this out. I've asked a couple of wrx wagon owners about the extra stance and it seems to work out pretty well with not a lot of downsides.
Time to source me some used control arms
Old 09-10-2007, 06:43 PM   #3
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Should be an interesting mod - you should have plenty of room under the fenders too...
Huffer is offline   Reply With Quote
Old 09-22-2007, 06:51 PM   #4
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Keep us updated,Sounds interesting.
Sneeky Pete is offline   Reply With Quote
Old 07-18-2008, 09:23 AM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Updating this:
It didn't go quite as planned, but the control arms are in there
Even at 0 camber, I didn't have problems rolling on 225's and a 48 offset wheel (7.5" width). I have about 3k miles on this setup and so far no transaxle issues.
I can't say about the wider track being the only contributor to the handling changes, but it is much more stable during high speed turns, turn-in's much more responsive, and it's not as tail happy as before (unexpected).
Old 07-18-2008, 10:54 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
You might not have axles problems now, but there is a reason sedan and wagon axles are different. I would probably throw some sedan axles in there just to be on the safe side.
Thats interesting that the wider front track you now have doesn't make the rear step out a little easier...
~Josh~
Old 07-21-2008, 05:35 PM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Neato.
DLC is offline   Reply With Quote
Old 07-21-2008, 06:21 PM   #8
MitchGT
Member#: 73684
2012 4Runner
Story on the headlights?
MitchGT is offline   Reply With Quote
Old 07-22-2008, 12:19 AM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
~Josh~
Actually there's wagon owners that have put 10,15,20k on this kind of setups without any problems either, but I'm not going to cry foul if anything happens. It's more likely a wheel bearing with go first I think...*knocks on wood*
The multi-link rear and wheel setup may have something to do with different handling characteristic that I've heard from impreza owners that went with the wider front track.
Old 04-19-2011, 09:31 PM   #10
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Just to update this. almost 3 years later and over 32k miles, still doing fine on the original axles, hubs, bearings (though I did have to replace one bearing/hub because the hub cracked from attempting to remove a stubborn ball-joint).
I bent my aluminum control arm. Can i put 02 control arms on for now? ki11switch Brakes, Steering & Suspension 4 07-14-2009 12:39 PM
OEM Alum. Front Control Arms on '04 WRX? hakkenpepper Brakes, Steering & Suspension 12 05-29-2006 03:23 PM
How many of you with aluminum control arms on your WRX modvp Brakes, Steering & Suspension 12 01-02-2004 01:37 PM
EJ20 X-member, do I need to go with WRX control arms on my GC8. underground-mpyre Subaru Conversions 8 09-25-2003 12:39 PM
Identical struts/ control arms on 02+ WRX & pre01 Impreza? pillaka Brakes, Steering & Suspension 1 02-24-2003 07:02 PM
