Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 09-08-2007, 12:30 AM   #1
Crazyhippy
Member#: 104881
1970 stg7 Porsche914
Default Will It work? 205 crank and rods in a 257 block
Just like the title says.. Can I install a 205 rotating assembly in a 257 block, w/ stock 257 pistons?
I spun a bearing in my Hybrid, and need to get the car running asap. I know i will have to re-build w/ the 257 crank and rods when they get back
Of course this thing might be so rev happy i'll keep it
Crazyhippy is offline   Reply With Quote
Old 09-08-2007, 12:47 AM   #2
Crazyhippy
Member#: 104881
It looks like the 257 pistons have a slightly higher pin height, so i'll end up losing a little bit of compression... No biggy though
Old 09-08-2007, 12:53 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you will loose a very noticable amount of CR and quench height will be horrid...shoot me a PM, you have a few options for the set up you are talking about and I might have an sti rotating assembly for sale.
Old 09-08-2007, 01:29 AM   #4
Crazyhippy
Member#: 104881
Answered my own question... It will not work. The 205 Rods are "square cut" on the small end, where as the 257 rod and piston are both cut on an angle @ the small end. The 205 rod will not fit the 257 piston stock...
Drawingboard, here i come.
Old 09-08-2007, 01:39 AM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
/\ WRONG!
You can grind/mill the rods to fit the STI pistons.
I did this build. I ran 30 psi. I did a 12.5 @ 112 with slipping clutch....
I used a phase 1 2.5 block with 2.2 turbo crank, the LONG rods, and stock STI pistons.
JDM B4 heads on EJ20G closed deck block-will it work great? renhoek Built Motor Discussion 2 08-17-2009 02:19 AM
Parts swap needed: My stock 2.5 crank and rods for your stock 2.0 crank and rods. HamFist RMIC Private Classifieds 4 04-17-2009 11:10 PM
How does a Cobb Accessport work and will it work with my parts? Twin_Cities_WRX General Community 5 03-08-2009 03:39 AM
FS CO: EJ22T short block, crank, and rods legacymaximus Engine/Power/Exhaust 12 02-24-2007 06:00 PM
STi Crank and rods in wrx SQB SNX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-14-2005 05:53 PM
