Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 09-08-2007, 03:13 AM   #1
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Default wideband help
i was wondering what is needed to have a wideband set up tuned with opensource. is the controller and gauge necessary? i don't understand exactly the whole wideband set up but the tuning is much more exact than compared to the stock 02 where it will set my car up in the neighbohood or its full potential. i think i fouled out my 02 sensor as well which is another reason why i ask this.
thanks
arco is offline   Reply With Quote
Old 09-09-2007, 12:03 AM   #2
arco
Member#: 57156
2007 V.8 207 STi
bump for answers
Old 09-10-2007, 06:13 PM   #3
mogrl840
Member#: 85298
Keep talkin **** you
are makin me famous
you can read the wide band on the laptop. You should always use a wideband o2 when tuning.
mogrl840 is offline   Reply With Quote
Old 09-10-2007, 07:34 PM   #4
arco
Member#: 57156
2007 V.8 207 STi
i understand that but i was wondering if a controller was needed or what not.
Old 09-12-2007, 04:26 AM   #5
Spec C Wannabe
Member#: 69170
wideband controller is needed when you want to convert signals from wideband to something readable in the laptop or other tuning program. Basically most of the wideband O2 set that are currently available in the market have WB controller included in the package.
What you really need is the datalogging program that can "integrate" WB reading into the logged data. Doing so help tuning fuel precisely down to Load/RPM point you want to address.
If you dont have the integration, you have to self-match WB reading with Load and RPM at any instance during log. This is not easy as these parameter change quickly when you do the full throttle logging.
Below is a list of paring between Dataloging/Tuning program and WB brand
EcuEdit can be integrated with Innovate LC-1, LM1, TechEdge and PLX Devices
Enginuity with LC-1
Cobb Tuning with LC-1 and LM-1 and may be some other brands
Ecutek with LC-1 and LM-1
Spec C Wannabe is offline   Reply With Quote
Old 09-12-2007, 08:32 AM   #6
blkscooby
Member#: 44422
2005 LGT
I use the LC-1 and Enginuity to tune customers cars. I made the LC-1 portable. You can also add a simple display instead of the more expensive gauges if you also want a quick visual display on the dash of the AFR.
blkscooby is offline   Reply With Quote
Old 09-12-2007, 03:07 PM   #7
rpbaetens
Member#: 157763
2005 STi
I have the LC-1 and Enginuity beta setup on my laptop. Works great. I even used one of the two programmable outputs on the LC-1 to drive a Autometer narrowband gauge just for my monitoring purposes. Saved a little money that route.
LC-1 $200
Autometer AFT $50
$250 total vs getting the Autometer wideband for $350 with no logging.
rpbaetens is offline   Reply With Quote
Old 09-12-2007, 04:47 PM   #8
WReXd
Member#: 114101
93 Impreza L Swap
i have heard many good things about the LC-1. thanks for the input. how is the Autometer AF gauge with the wideband? does it work well because i have one lying around somewhere. i know it won't be accurate for tuning's sake but to view for monitory purposes as you mentioned. It is the autometer phantom gauge btw. i heard it was crap though.
WReXd is offline   Reply With Quote
Old 09-12-2007, 11:16 PM   #9
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
^^^You'd have to program one of the outputs to narrow band for the Autometer AF to work anywhere close to accurate.
Old 09-13-2007, 02:21 AM   #10
arco
Member#: 57156
2007 V.8 207 STi
^^^really? why is that so? i don't understand why that would be more accurate?
Old 09-13-2007, 11:21 AM   #11
Not-EWRX
Member#: 158043
2013 Wrx Hatch
I'm working on my Wideband set up right know. I a'm quite fimilar with enginuity for data loging but how do you log the wideband at the same time as the enginity log.
Not-EWRX is offline   Reply With Quote
Old 09-13-2007, 02:41 PM   #12
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Which gauge is it? The regular AF gauge with nothing but the LEDs swinging back and forth? Or is it the Wideband version? From your mention of being "not usable for tuning" I'd guess it is the narrowband version, if you use the LC-1 you'll need to setup one of the outputs for narrowband. Wideband reads from 0-5v while narrowband is only 0-1v, so on default settings it'll just be pegged lean unless you program it.
Old 09-17-2007, 12:41 PM   #13
Robertob
Member#: 147254
2005 9-2x
If you have an Innovate wideband, there is an enginuity test release that allows you to log the wb at the same time as the rest of the data. The Innovate software also works with the Tactrix cable for DL stuff.
Robertob is offline   Reply With Quote
Old 09-17-2007, 01:45 PM   #14
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Were do you get the test release do you just download the lattest revision?
Old 09-17-2007, 01:53 PM   #15
Freon
Member#: 88322
2009 BMW 135i
There is a thread with "LC-1" in the title on Enguinity forums. I think in the Development forum.
Freon is offline   Reply With Quote
Old 09-17-2007, 05:59 PM   #16
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
Did you buy the tailpipe clamp that innovate sells or make your own. I've been thinking about putting one together versus spending $75 bucks on one.
Casey is offline   Reply With Quote
Old 09-17-2007, 07:11 PM   #17
Master2192
Member#: 83254
98 2.5 RS
04 WRX
You should install the wideband in the downpipe when tuning as the resolution will be better and reaction much faster. On all my customer cars I'll remove and zip tie the rear O2 sensor out of the way and install my wideband in there (only works if the car is CATLESS). If they have a catalytic converter they need to have a bung installed before the cat after the turbo.
Old 09-17-2007, 08:16 PM   #18
Freon
Member#: 88322
2009 BMW 135i
You can't just leave the rear O2 ziptied out on a 2.5L turbo car...
Old 09-18-2007, 11:27 AM   #19
arco
Member#: 57156
2007 V.8 207 STi
what do you think about these two gauges? if these don't seem adequate, what is?
http://www.dynotunenitrous.com/store...?idproduct=171
http://www.moates.net/product_info.p...roducts_id=134
wideband. Help!!!!! breezeby Open Source Reflashes 21 01-07-2013 09:33 AM
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
Roaring noise? previous crash damage, need help gotboost954 Transmission (AT/MT) & Driveline 7 12-24-2009 11:33 PM
wideband help mysticowboy Other Engine Management 1 07-22-2006 03:29 PM
