Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 09-09-2007, 12:02 PM   #1
proletariandan
Member#: 88436
in t he market again
Default Tips for removing lower coolant line on turbo?
I feel like a moron because this is supposed to be an easy install, but I can't for the life of me see how to get this off. There is no way to get any kind of leverage on the little clamp and even if you could you can't move it much because it runs into the heatshield-wrap on the rubber hose. Do people just muscle it off with the clamp on there?!?
Thanks,
Dan
proletariandan is offline   Reply With Quote
Old 09-09-2007, 12:18 PM   #2
M.R.blue
Member#: 89589
fyi the stock upper and lower coolant turbo hose are one piece.U have to remove the 2 bango bolts of upper and lower coolant hose (hard lines).
M.R.blue is offline   Reply With Quote
Old 09-09-2007, 12:21 PM   #3
proletariandan
Member#: 88436
That goes against every writeup I've seen - They all say just to pull the hoses off of the coolant lines from the turbo. The top one wasn't a big deal, although it spilled quite a bit of coolant all over the place, since I was expecting it to come from the line and not the turbo itself.
Old 09-09-2007, 12:26 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...d000000d......long needle nose....squeeze clamp and pull it UP onto the hose as far as is possible....push---yes PUSH the hose down while twisting it---and avoiding blood donation ......as soon as ya feel it 'give' pull it off the hardpipe and done.
re-install is easy BUT!!!!!....push the hose on a bit farther than ya want it....put the clamp back just below the bead on the hardpipe and gently PULL the hose so that the clamp is pulled up against the bead on the hardpipe.
I chased THAT ****ing leak for 2 weels, once
Uncle Scotty is online now   Reply With Quote
Old 09-09-2007, 12:27 PM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....no as in NOT
Old 09-09-2007, 01:38 PM   #6
proletariandan
Member#: 88436
Well there was no way it was moving back, I just forced it off the front with the needle nose...hopefully getting it back on won't be suicide.
Old 09-09-2007, 01:55 PM   #7
LewisWORX
Member#: 63001
02 WRX Stg. II PnP
I also had a leak from that line for forever after the reinstall. You will notice that the hard line bends as it gets closer to the block. I pushed the tubing too far down over the bend and it created a bit of an opening for coolant to drip out. That line is definitely a pita.
LewisWORX is offline   Reply With Quote
Old 09-09-2007, 02:58 PM   #8
proletariandan
Member#: 88436
I came to find out the uppipe is installed incorrectly and the bolts (yes, bolts) are seized in the holes where the studs were supposed to go I should be done already but I can't even get the turbo out thanks to the asshat who fvcked this install up the first time
Old 09-10-2007, 12:50 AM   #9
wrxl98
Member#: 101244
2003 wrx sportwagon
silver cobb stage 2.5+
i didn't trust the stock clamps so i replaced them with small hose clamps. access was horrible.
also didn't think i would ever get the banjo bolt to thread back in but it did after dozens of attempts.
wrxl98 is offline   Reply With Quote
Lower Coolant Line Question dr doom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-17-2008 01:07 PM
Coolant line on turbo Oas1s Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-02-2007 07:09 AM
need tips to remove lower strut bolts WRCwagon Brakes, Steering & Suspension 16 08-31-2007 12:12 AM
coolant lines on td04 NeaD Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-13-2004 12:09 AM
Need Torque Specs For Banjo Fitting on hard oil line on turbo 2.2gotboost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-06-2003 07:30 PM
