Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 09-09-2007, 12:03 PM   #1
acidrain088
Member#: 130973
Default v5 swap done but won't idle right
i just completed my v5 swap into an 95 impreza land the engine runs great except for at idle. the only mod is a snorkus delete after it has warmed up the idle searches between 400 and 1000 rpm. to try and fix the problem we preasure tested the intake and found no leaks. we also redid the grounds. that helped some but still didnt fix it. the only thing we think it coild be is the idle controler. any thoughts what it could be?
acidrain088 is offline   Reply With Quote
Old 09-09-2007, 12:51 PM   #2
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Maybe the wiring to the idle control valve??
or
Have U already tried cleaning the IACV itself
Unscrew it from the car, open it up and use brake-cleaner/degreaser to clean it.
or
The Idle air controller itself has slotted holes, so there is some adjustment possible there, start the car, loosen the 2 bolts, and the valve assembly can be turned a bit (2 or 3 mm)
Just turn it untill it idles correctly.
Dutch Scooby lover is offline   Reply With Quote
Old 09-10-2007, 06:45 PM   #3
wrxforme1
Member#: 137047
2006 2006 WRX TR
WR Blue
Make sure all your hose clamps are tight too, so there aren't any leaks.
wrxforme1 is offline   Reply With Quote
Old 09-13-2007, 03:38 PM   #4
TAYFUN
Member#: 151855
2002 WRX UK300 SWAP
MICA BLUE
i had the same problem with my 2000 rsti had an 2005 sti engine but after i dynoed it it went away
TAYFUN is offline   Reply With Quote
Old 09-13-2007, 03:51 PM   #5
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
That would be a coincidence, really.
Nothing a dyno does isn, y done while just driving it spirited on the road or at the track.
Won't idle right KyoSaNim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-13-2007 11:33 AM
ej207 v5 swapped from vf28 to vf34 not runs rich @ idle impreziv25 Subaru Conversions 6 05-24-2007 04:46 PM
swap done.. but i have a problem..help! xtian Subaru Conversions 43 02-23-2006 06:56 PM
When I'm done, she won't walk straight or poop right for a week. Snoopy Off-Topic 26 01-07-2005 01:17 PM
jdm swaps done, but need to reset ecu! help 99WRXEJ20 Subaru Conversions 6 07-02-2003 06:57 PM
