Old 09-09-2007, 02:44 PM   #1
islichlorgan
Member#: 101431
2005 sti
crystal grey
Default first time at the track , and not so happy
i went to the track yesterday and i m not so happy with the result, here's the score!!
reaction :.385
60 :1.858
1/8th:8.224
e.t :12.677
mph :117.112
what could be improved ..... need some adviced
car is a 2005 sti with a UR t3/t04s rotated mount
with all the supporting mods 900 cc injectors
forged internal etc etc..... it put down 415 whp at 20 lbs
the car boged on 3 run , when i shift into 3 rd the boost didnt go any higher than 10 lbs and on all the other gears 1 got 16 lbs instead of the 20 lbs i usually get . the car as a ****ty tune so ill get a tune and then, back to the track
islichlorgan is offline   Reply With Quote
Old 09-09-2007, 02:50 PM   #2
Speed
Member#: 67371
05 BUILT 2.4L STI
Practice, practice, practice and a better tune!
Speed is offline   Reply With Quote
Old 09-09-2007, 02:59 PM   #3
r0nzar
Member#: 78957
'06 Evo IX RS
White on white on salt
you answered your own questions. your tune and driving aren't that great. Practice driving, get a better tune and you'll be rockin
r0nzar is offline   Reply With Quote
Old 09-09-2007, 03:03 PM   #4
islichlorgan
Member#: 101431
2005 sti
crystal grey
i now i need practice but a 1.8 aint that bad and 117 mph thats good for 11.9** or lower aint it
Old 09-09-2007, 03:30 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Well if you want to get technical a 1.86 is wayyy closer to a 1.900 than a 1.700. And im going to ASSume that you ran more than once and this was your best run and most of the other ones you ran a 1.9+ 60 foot. Also with your power you should be able to cut some 1.6 60 foots.
And yes the 117 mph is good for as low as 11.7.
Maybe think about getting a UTEC with the Launch Control and Flat Foot Shifting capabilities.
Your slip is almost identical to my old ones with my WRX. Had a **** load of work done and the best 60 foot i could muster was a 2.0 (i used to run 1.8's consistently before the work).
my wrx (also this was on 91 octane)
60' = 2.0+
ET = 12.7
TRAP = 114-115 mph
I am also going to ASSume that your car was tuned on pump gas since you are only pushing 20psi. Get your car retuned and get a race gas tune also. You should be able to crack 11's on the race gas tune with your current driving.
And if you are having boost problems maybe you need to upgrade your exteranl wastegate spring, or get an external wastegate if you didnt get the whole kit, or get a new boost contol solenoid.
Old 09-09-2007, 03:41 PM   #6
islichlorgan
Member#: 101431
2005 sti
crystal grey
on all my run i did 1.8** never did any higher and yes this was my best run all the other one were baddddd , the car was tune on 94 octane and im in big need of a stiffer spring i only got a 12 pounds spring , but im sure that with a tune my problem will be solve and ill see some 11.9** pass .... at least i wish
Old 09-09-2007, 04:07 PM   #7
Speed
Member#: 67371
05 BUILT 2.4L STI
Remember is not all about the 60ft, shifting plays a mayor role... especially in a STi. With 118 traps I manage 11.6... I'm sure with a little bit more practice 11.5 or 11.4 is within reach on the pump gas map.
Old 09-09-2007, 04:33 PM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
^ Damn Speed howd you manage a 1.5 60'!
PaulRex is offline   Reply With Quote
Old 09-09-2007, 04:48 PM   #9
Speed
Member#: 67371
05 BUILT 2.4L STI
Practice Believe it or not this was done on 245/45/17 RE01-R. They stick pretty good.
But I also do other things to help out the launch like (setting the suspension, a little weight reduction plus I'm using a Hydra).
Old 09-09-2007, 04:52 PM   #10
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
nice.. if you have coilovers do you set the dampers really soft in the rear for some squat?
Old 09-10-2007, 10:37 AM   #11
Speed
Member#: 67371
05 BUILT 2.4L STI
I don't have coilovers right now... but I do try to shift some weight to the back.
First time at the track, horrible times. But not the last time going. 06BLUEREX Proven Power Bragging 25 08-14-2006 02:03 PM
First time at the track and my first post ihaveanose1234 Proven Power Bragging 6 05-21-2006 01:33 PM
First time at the track...Evo III times KKoepp31 Proven Power Bragging 22 01-09-2004 05:55 PM
First time at the track...Are these good times? wrichiex_sti Proven Power Bragging 6 10-24-2003 05:03 PM
First time at the track ..here are my times v6scoobie General Forum Archive 11 09-09-2000 07:13 PM
