Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 09-09-2007, 07:23 PM   #1
03clipsegts
Member#: 117692
2004 30R STI
Default need help with coolant lines on a perrin rotated kit
Does anyone have any pics of the way they extended and hooked the coolant lines to a perrin rotated turbo kit. They way i did it was put the banjo bolts facing straight up and extended the line so it like makes a U down to the turbo. I dont know it kinda looks wierd.
03clipsegts is offline   Reply With Quote
Old 09-09-2007, 07:26 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
That sounds correct, lemme dig up some pics...
jays05 is offline   Reply With Quote
Old 09-09-2007, 07:28 PM   #3
jays05
Member#: 78165
05 STI 35r + e85
Best I can do
Old 09-09-2007, 07:29 PM   #4
03clipsegts
Member#: 117692
2004 30R STI
thanks that would be a big help
Old 09-09-2007, 07:31 PM   #5
03clipsegts
Member#: 117692
2004 30R STI
awsome man thats pretty much how i have it. now im wondering what i am going to about the pcv cause i was just planning on running a filter right off the turbo. Any ideas?
Old 09-09-2007, 07:38 PM   #6
03clipsegts
Member#: 117692
2004 30R STI
i think that is was its called anyways. I bought the blow thru instead of the intake hoping just the filter would be fine.
Old 09-09-2007, 07:43 PM   #7
jays05
Member#: 78165
05 STI 35r + e85
If you're running a filer right off the turbo, I think your only option is something that vents to atmosphere... maybe an element tuning air/oil separator?
Old 09-09-2007, 07:47 PM   #8
03clipsegts
Member#: 117692
2004 30R STI
Yea i honestly dont know anything about what that even does. I saw it when i took the stock inlet off yesterday and was like hope i dont need this lol
Old 09-09-2007, 08:05 PM   #9
modaddict
Member#: 95840
sold to a good bud
awaiting next car
old kit:
modaddict is offline   Reply With Quote
Old 09-10-2007, 09:42 AM   #10
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Here is mine. This is my old setup that had the upper coolant reservoir bolted to the passenger strut tower - you can see the other coolant line going up right behind the turbo.
Now I'm running a hose straight from the turbo to the outlet on the water pump and completely deleted the upper coolant reservoir.
SloRice is offline   Reply With Quote
Old 09-11-2007, 12:56 AM   #11
03clipsegts
Member#: 117692
2004 30R STI
awsome thanks for the pics guys. How did the perrin kit match up with your cat backs and what brands do u guys have?
Old 09-11-2007, 12:59 AM   #12
modaddict
Member#: 95840
sold to a good bud
awaiting next car
*MINE* sucked balls. I had to pry the whole exhaust over to make it fit. I have the Greddy Evo2. It always sat crooked. I though the catback was bent. When I changed my turbo kit to Crawford....I realized it wasn't my catback, but the downpipe/turbo kit was bent wrong............
Old 09-11-2007, 09:20 AM   #13
03clipsegts
Member#: 117692
2004 30R STI
yea it deff seems that its bent wrong. Even the flange seems bent wrong I cant get it to pull together on the bottom. I can wiggle the gasket back and forth thats how bad it is.
Old 09-11-2007, 11:02 AM   #14
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
I had an HKS Carbon-Ti, then an old Buschur Racing catback and then a new Buschur Racing catback. All 3 of them didn't line up with the Perrin downpipe.
I recently installed a used old Greddy Evo and it lines up perfectly.
Old 09-11-2007, 12:29 PM   #15
03clipsegts
Member#: 117692
2004 30R STI
Wow thats pretty wierd. I am just gonna reweld the flange on my cat back. Hopefully I can just get it to not leak.
Need help with coolant tgraci Newbies & FAQs 0 08-10-2009 01:31 PM
need help with fuel line setup bloopsta26 Factory 2.5L Turbo Powertrain 4 09-03-2008 10:15 PM
Need help with vac line... Strng1dah Factory 2.0L Turbo Powertrain 3 12-31-2007 01:12 AM
need help with coolant line hook up dt311 Factory 2.0L Turbo Powertrain 3 04-18-2005 05:01 PM
Help with coolant lines smacksube Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-17-2002 10:03 PM
Message Board Statistics All times are GMT -4. The time now is 07:10 AM.
