Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 09-10-2007, 02:12 PM   #1
imprezaowner27
Member#: 131299
2006 Impreza
Default Fog Light Relay
Car- 2006 Subaru Impreza 2.5i
I have the fog light switch installed, i have aftermarket fogs that i know how to wire to the car...
i just dont know where the relay goes? under the dash? in the engine compartment?
what slot do i put it in?
could someone pm me a picture or something?
imprezaowner27 is offline   Reply With Quote
Old 09-10-2007, 02:40 PM   #2
imprezaowner27
Member#: 131299
2006 Impreza
wow no one?
Old 09-10-2007, 05:35 PM   #3
Paranoid Fabrications
Member#: 140712
2008 WRX STI
its under the dash. if you look at the fuse box the relay gos off to the right side.
see the relays off to the right.
Shane
Paranoid Fabrications is offline   Reply With Quote
Old 09-11-2007, 12:15 AM   #4
imprezaowner27
Member#: 131299
2006 Impreza
Shane
yes i found that box, but there are 2/3 empty slots, which one is it?
Old 09-11-2007, 12:27 AM   #5
Member#: 140712
2008 WRX STI
look at that white sticker. it shows what relay does what.
if it doesnt, you have a 1 in 3 shot of finding the right one the first time
Shane
Old 09-11-2007, 12:59 AM   #6
imprezaowner27
Member#: 131299
2006 Impreza
Shane
lol thanks, the one that says FOG on it is pointing in the opposite direction HAHA
the relay wont burn or break if i use trial and error will it?
Old 09-11-2007, 12:32 PM   #7
Member#: 140712
2008 WRX STI
nope, should just not work
Old 09-11-2007, 12:36 PM   #8
Member#: 140712
2008 WRX STI
ok, i went and looked at mine to see if i could see which one it is, but i have every socket filled with relays so, sorry, no help
Shane
Old 09-11-2007, 03:41 PM   #9
imprezaowner27
Member#: 131299
2006 Impreza
Shane
haha thanks anyway i got it!, first try too...its like, the second one or third on up HAHAHA no help at all if anyone else is reading this, but it works
Old 09-15-2007, 07:17 PM   #10
mtntrekker30
Member#: 158173
Talking 1999 OBS fog light relay
Would this be the same for a 1999 Outback sport? I'm trying to find the relay switch for my fog lights too. I've read on here look for a pink plug or look of a black plug but none of them seem to work. Does anyone know the part # or the # that should be on the relay as well? I've called about 4 dealerships and all of them seem to have different answers. Thanks.
mtntrekker30 is offline   Reply With Quote
Old 10-21-2007, 10:09 AM   #11
doogie1303
Member#: 100536
1999 Impreza Outback
Lightbulb Relay P/N and wiring question
I just ordered a relay and switch to put fogs in my 1999 OBS from subarupartsforyou.com, here is my invoice with p/n:
Item Name: RELAY FOG LAMPS FOR 1993-2001 IMPREZA
Item #: 82501FC100 or AEO3A (wrong P/N see update below)
Unit Price: $9.00
Quantity: 1
Ship Method: UPS Ground -- residential
Item Name: SWITCH FOG LAMP FOR 1997-2001 IMPREZA located on dash left
side of steering wheel
Item #: 83001FA051
Unit Price: $29.00
Quantity: 1
Now as far as the plug, are you asking about the plug for the relay or the plug for the switch? The plug for the switch I believe is the grey plug next to the cruise control switch, at least thats what I have in my OBS.
Now here is a question for people who have installed factory fogs before, where the heck is the plugs for the factory foglights to plug into on the 1999 OBS? I have had my hands all inside the bumper on both sides and cant seem to find them. Does the factory install kit come with some sort of extra harness? The only plug I found is a two wire plug taped up on the drivers side headlight and no plug on the opposite headlight. I thought all imprezas in 1999 had wiring for fogs. I didn't order an OEM kit since I'm putting in aftermarket fogs (non HID) and I want to use the stock wiring. If anyone has the OEM instructions for the kit, that would really help.
UPDATE (11/10/07): The fog light relay that I received was the wrong type. I received the Square type fog light relay (82501FC100) used in the 2002+ Imprezas, the pre 02s use the round style type relay (82501AA130) which plugs into a pink pluig located to the left of the fuse box under the dash. I got it from my local subaru dealer for $22. BTW, the relay above the fog light relay with the blue plug is the power window relay, I used that relay to test the fog light connector prior to buying another relay.
Also I confirmed that the two wire plug taped up on the drivers side headlight is the fog light connector. Reading in another forum, the OEM fog light kit comes with a harness which extends from that connector to each foglight. Since I have aftermarket non-hid fogs, I will just make my own harness using the wiring that the aftermarket fogs came with and tap off that connector on the headlight. Now I just need to wait for a day where it isn't frezzing out so that I can mount the fogs.
doogie1303 is offline   Reply With Quote
Old 11-12-2010, 07:48 PM   #12
the_black_one
Member#: 79021
1998 OBS ver.5 repl
smoky granite mica
^^^^^ Thanks a ton for the info. Installing RS fogs in a 98 OBS - RS conversion...
the_black_one is offline   Reply With Quote
Old 11-12-2010, 11:28 PM   #13
hjmik
Member#: 222835
2007 Forester
Quick question! Is there a relay that I can use substituting OEM factory fog relay? I really need one ASAP can't wait for shipping...
Is there something I can buy from Radio shack or anywhere else?
EDIT: Do you know if this will work??
http://www.radioshack.com/product/in...rodsPerPage=60
hjmik is offline   Reply With Quote
Old 11-12-2010, 11:47 PM   #14
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
nope, suby relays have a different pin setup. find a dealer and order one. and its just your fogs, its not like you cant live with out those for a few days LOL
PARANOID56 is online now   Reply With Quote
Old 11-12-2010, 11:57 PM   #15
hjmik
Member#: 222835
2007 Forester
I was going out truck in few days where I do need fog lights lol Hopefully they can get one for me before I head out of town
Old 11-13-2010, 12:09 AM   #16
PARANOID56
Member#: 22035
2003 Brocoma DCab
you might be able to rig up a normal relay to work, but your best bet is still your local dealer
wrx fog light relay bemani Electrical & Lighting 20 02-11-2015 05:51 PM
Fog Light Relay? BusHonk Outback Forum 2 04-26-2004 04:32 PM
1997 Outback Fog Light Relay BusHonk Electrical & Lighting 5 04-02-2004 01:32 PM
I couldnt find fog light relay of my 98OBS yeng Electrical & Lighting 1 02-16-2004 01:26 PM
fog light relay ? ScooBimmer Electrical & Lighting 3 07-01-2003 09:41 PM
