Old 09-10-2007, 02:54 PM   #1
djosrs
Member#: 101730
02 WRX
Stage III+ PPG Reppin!
Default 02 WRX Stock Turbo vs 06 WRX Stock Turbo
Alright, without doing much research I have a question.
I have an 02 WRX with a stock turbo and need to upgrade, however I only need to upgrade right now because my turbo is too old and I think some of the bearings are going bad, the turbo has 74K miles on it and has been pushing 18+ psi for 35K of those miles.
I kinda want to just grab a stock turbo off an 06 WRX.... what is the size difference. What turbo is on the 06 WRX?
HELP PLEASE
djosrs is offline   Reply With Quote
Old 09-10-2007, 03:37 PM   #2
Mayor McCheese
Member#: 117018
79 Rexor on Dubs
Paws McGillicutty
TD04 same as the 02.
Mayor McCheese is offline   Reply With Quote
Old 09-10-2007, 03:38 PM   #3
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
I think they are both TD04's.
StarDogChampion is offline   Reply With Quote
Old 09-10-2007, 04:00 PM   #4
djosrs
Member#: 101730
02 WRX
Yeah did some research and thats what I heard .... that must spool up very nicely on the new WRXs then
Old 09-10-2007, 06:02 PM   #5
thosepeople
Member#: 133104
2002 silver WRX
oh yes 4:11 gears
You might as well have some P&P done on the turbo if your going to swap with a stock unit. You won't regret it!
thosepeople is offline   Reply With Quote
Old 09-10-2007, 10:38 PM   #6
Haelan
Member#: 151045
2013 Subaru STI
CBP
I have an 04 and did an install with an 06 TD04. I found two differences.
First, the restrictor pills are different. The 06 had a smaller diameter opening in the center. Caused my car to overboost like crazy until I changed it out and adjusted the wastegate actuator arm.
Second, the compressor housing does not have a slight 'bend' like my 04 TD04 did. It made the connection to the intercooler hose a little difficult, but possible.
Just my 2 cents.
Haelan is offline   Reply With Quote
Old 09-11-2007, 08:52 AM   #7
quazimoto
Member#: 70395
Just my 2 cents.
Yup.got pics of the two here
http://forums.nasioc.com/forums/show...3&postcount=32
quazimoto is offline   Reply With Quote
Old 05-06-2013, 11:18 PM   #8
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
So when u swapped the 2.0 turbo with the 2.5 turbo did u have to do anything with the wastegate actuator?
And how does the car feel with the turbo on it, and differences?
shamrock 05 is offline   Reply With Quote
Old 05-07-2013, 12:14 AM   #9
wrxlaunch
Member#: 181298
Why would the car feel different with the tdo4 from an 06 which is exactly the same as the tdo4 from a 2002?
wrxlaunch is offline   Reply With Quote
Old 05-07-2013, 12:16 AM   #10
Haelan
Member#: 151045
2013 Subaru STI
CBP
Wastegate actuators also need to be swapped. The springs have different tensions.
Everything felt the same...
Old 05-07-2013, 03:34 PM   #11
shamrock 05
Member#: 120057
They are not the same as plug and play "wrxlaunch" see above.
Old 05-07-2013, 04:16 PM   #12
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Very interested to know what type of research you did as these questions should not be questions if you researched.
Dr. octagon is offline   Reply With Quote
Dyno Sheet Request: 06 WRX vs 06 WRX Cobb Stage 1 karnick Proven Power Bragging 7 01-03-2007 05:15 PM
02-05 WRX at Stage 2 vs. 06 WRX Stock/ Stage 1 fun factor poll Petrus General Community 55 05-11-2006 07:55 AM
Exhaust sound of 06 STI vs. 06 WRX Xens Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-11-2006 03:32 PM
looking for stock 05 vs 06 WRX on same Dyno? theicewall Engine Management & Tuning 1 11-16-2005 08:04 PM
05 wrx stage 2 vs 06 wrx stage 2? dodiox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-11-2005 11:31 AM
