Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 09-10-2007, 09:56 PM   #1
dtpebs
Member#: 98084
2008 WRX Sedan
Charcoal Grey
Default Open ECU boost cut - several questions
06' WRX -- TBE, VF-39, HKS SSQV, TMIC, SRI.
I'm currently running Open ECU w/ the stage 2 Cobb OTS vf-39 map 91 octane. I am located in Ohio and running 94 octane however, I do not a 93+ octane map available to me. After drilling out the pill to Cobb's specifications and replacing the vaccum line with an auto zone line (tore the old one trying to get the pill out) I am still having trouble with hitting boost cut, which should not be happening. My question, is the auto zone vaccum line (harder rubber) perhaps not functioning as well as the stock subaru line, potentially causing the pill to shift or turn on its side decreasing the air flow cuasing for boost cut? Would I be able to run a boost controller to eliminate the pill and the problem and will it be compatible with Open ECU? Or will upgrading to the GM solenoid perhaps play any role in fixing this? Any input is greatly appreciated.
dtpebs is offline   Reply With Quote
Old 09-10-2007, 10:02 PM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
wait, why do you have a cobb ots stage 2 vf39 map with openecu....?
Nuke209 is offline   Reply With Quote
Old 09-10-2007, 10:04 PM   #3
dtpebs
Member#: 98084
2008 WRX Sedan
Charcoal Grey
The cobb map is the only map I have available.
Old 09-10-2007, 10:07 PM   #4
dtpebs
Member#: 98084
2008 WRX Sedan
Charcoal Grey
OTS maps that have been uploaded to a car can be pulled by using OpenECU and a tactrix cable. This is the map that was pulled for use in my car. In this case the only available map was this cobb.
Old 09-11-2007, 12:13 PM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
I suggest you begin doing some tuning or get another map, I do not suggest using 'cobb's stuff with OpenECU
you can buy the xpt stage 3 map
Old 09-11-2007, 12:36 PM   #6
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
I won't comment on the possible legalities here since you didn't state whether or not you own an AP.
About the tuning have you taken logs? What is causing you to hit fuel cut? are you over boosting or is the fuel cut PSI set too low for the level of boost you are trying to run?
brettm is offline   Reply With Quote
Electronic Boost Controller.....port question?? Tempest1o1 Newbies & FAQs 3 06-03-2010 07:39 PM
Open ECU boost cut issue, several questions dtpebs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 09-13-2007 01:14 AM
17.4 psi, boost cut, cel question slvrwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-24-2002 05:13 PM
Hitting Boost Cut and CEL with VF30 + EBC + stock ECU gazoline Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-15-2002 07:58 PM
ECU Boost Cut awu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-10-2001 02:41 PM
