Old 09-10-2007, 10:16 PM   #1
slvrwrx03
Member#: 155183
2003 WRX
Default cant connect using tactrix cable
I have a tactrix cable and enginuity but Im unable to connect to the ecu I searched and found out that you need the drivers for the cable but when my computer trys to install them it always fails any help would be great I was told this would work and now Im starting to think I wasted the money for the cable please help
slvrwrx03 is offline   Reply With Quote
Old 09-10-2007, 10:20 PM   #2
dtpebs
Member#: 98084
2008 WRX Sedan
Charcoal Grey
Software for d/l and up/l maps: http://www.openecu.org/index.php?title=EcuFlash
Go there, download that ecu flash program. I have an older laptop, similar problems you had. This program worked for me.
dtpebs is offline   Reply With Quote
Old 09-10-2007, 10:51 PM   #3
slvrwrx03
Member#: 155183
2003 WRX
Im mainly wanting to datalog can I do this with that software thanks for the help
Old 09-11-2007, 02:54 AM   #4
dtpebs
Member#: 98084
2008 WRX Sedan
Charcoal Grey
Stick with enginuity for datalogging.
Old 09-11-2007, 10:37 AM   #5
slvrwrx03
Member#: 155183
2003 WRX
I want to use enginuity but I cant get it to connect can someone help
Old 09-11-2007, 11:05 AM   #6
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
When it asks to install the drivers you need to tell it you want to manually install them then tell it to look in program files->openecu->ecuflash->drivers->x86. The laptop will go through this process 2 times and you have to tell it where to look both times.
06rexwagon is offline   Reply With Quote
Old 09-11-2007, 11:07 AM   #7
RedRicer
Member#: 128810
05 STI
CGM
Default You need the right maps and version
The maps and versions must be correct or it will not work. Go to enginuity.org and follow there directions. It works for me on an 05 sti no problem. If you have an older laptop with an older os it could be problems with your USB not recognizing the cable or having the drivers.
Or do what he says ^^^^^^^
RedRicer is offline   Reply With Quote
Old 09-11-2007, 04:51 PM   #8
slvrwrx03
Member#: 155183
2003 WRX
I did exactly this and then came to put down what I had done and you had left this message I appreciate it tho thats the way to do it because the drivers for the tactrix cable come with ecuflash so I just used the advanced feature on the install box to find the drivers and then installed then and it worked perfectly thanks again for all the help
Old 09-11-2007, 05:31 PM   #9
06rexwagon
Member#: 114730
[email protected]
Hey glad it worked!
Old 09-25-2007, 09:46 PM   #10
Foska Oats
Member#: 144081
2003 WRX
I just downloaded mine. Thanks much.
Foska Oats is offline   Reply With Quote
Tactrix Cable Ryan314 Private 'Wanted' Classifieds 3 07-06-2010 10:50 AM
Anyone know how to use tactrix cables? shanemono4 Rocky Mountains Impreza Club Forum -- RMIC 5 05-09-2008 08:42 AM
Using Tactrix Cable for OBD2 Scanning... nperkins Commercial ECU Reflashes 6 07-25-2007 09:45 PM
so where do i connect tactrix cable? stevey323 Newbies & FAQs 3 03-10-2007 07:00 PM
Where to connect tactrix cable on 2006 WRX? eggeegg Newbies & FAQs 12 02-10-2007 07:39 PM
