Old 09-11-2007, 10:25 AM   #1
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
Default Poor numbers at 90.7 degrees
I put my car on the dyno last night with my engine taking in an amazing 90.7 degree air. I only pulled 216whp and 196wtq. Ill put the sheet on as soon as I get a scanner. This was on dyno packs by the way.
Power Mods:
Hks up, down and Hi-power
Cobb short ram intake
turbosmart dual port bov
Open ecu stage 2 tune running 17.5 psi
Ntercooled is offline   Reply With Quote
Old 09-11-2007, 10:40 AM   #2
Freon
Member#: 88322
2009 BMW 135i
What were your actual intake temps? There is a difference between ambient temp and intake temps.
I suggest going back to a stock BOV.
Freon is offline   Reply With Quote
Old 09-11-2007, 10:43 AM   #3
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
that was the intake temps, the dual port doesnt effect the performance but I'm about to install a 18g with external gate and fmic so I think ill keep it.
Old 09-11-2007, 11:04 AM   #4
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
tune is bad and so is something esle in the car i suspect bov or cobb intake
bren wrx is offline   Reply With Quote
Old 09-11-2007, 11:08 AM   #5
Foo_Blyat
Member#: 93750
2008 GSX-R600
Massive STi Part-Out
the downpipe is also crap, but i guess you baught it for the EWG setup, where it wont matter.
Foo_Blyat is offline   Reply With Quote
Old 09-11-2007, 11:12 AM   #6
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
I figured it was the tune but im gonna just wait till i get the new setup to tune again.
Old 09-11-2007, 12:16 PM   #7
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Probably a combination of a relaxed tune, or safe tune whatever you want to call it.. bad tune lol.. and the high temperatures, and maybe heatsoak. You'll do better next time definatly, especially since you have a tuned map to start from.
And if your going EWG that is great, but from my experience with the stock turbo and using a OEM style flat flanged downpipe (stromung) which is pretty much same design as HKS..even though it looks like crap, it really is not a limiting factor with the stock turbo IMO.
PaulRex is offline   Reply With Quote
Old 09-11-2007, 12:43 PM   #8
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
^^^^^^I totally agree. The HKS gets a really bad name but it is just fine for anything 300whp and below.
JMK508 is offline   Reply With Quote
Old 09-11-2007, 08:22 PM   #9
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
well that good now i can get rid of this Dunce hat i've been wearing all day.
[email protected] .... [email protected] 1/8th Junior2JZ Proven Power Bragging 29 04-01-2009 03:59 PM
6 months between alignments. I lost .7 degrees of camber and cant get it back. Why? BGPKR Brakes, Steering & Suspension 6 03-11-2005 10:45 PM
7 degrees outside :furious: eurojax Off-Topic 11 11-02-2004 08:52 AM
-1.7 Degree camber in rear? Drews_WRX Brakes, Steering & Suspension 3 06-23-2003 03:02 AM
90 - 100 degrees Celcius oil temp normal? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 04-11-2003 02:21 PM
