Closed Thread
Old 09-11-2007, 11:23 AM   #1
dukeduster
Member#: 95789
2002 WRX PTE
6262, hydra, 1100 FIC
Default BLEW MY AXIS STAGE 2 lol
Well guyts it was fun for about 6k miles. But now I must be moving on and nputting a better engine in my car. THe engine took quite a bit of abuse before then rings went out. But i just cant help but think that the piston that the rings went out on was already bad. As soon as the engine went in the piston that went bad wouldnt fire from day 1 properly but did have good compression. in the initial tuning the was some harsh detonation But I had gotten it where there was no detronation. Well not a bad engine just couldve been better.
dukeduster is offline
Old 09-11-2007, 11:53 AM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
what do you mean the piston wouldn't fire?...sounds like an electrical or plug issue to me.
Homemade WRX is offline
Old 09-11-2007, 12:19 PM   #3
dukeduster
Member#: 95789
2002 WRX PTE
Well on a REALLY cold satrt that piston would not fire until the engine temp came up!
Old 09-11-2007, 12:57 PM   #4
radve
Member#: 155256
2000 sti ra
multi colour
Default axis engine
sounds like the detonation could of damaged the engine not a bad engine its not normally the engines fault it detonates ,its the tuning.
If there was enough oil in the cylinder to cause det and misfire from cold it would of smoked like a train .
radve is offline
Old 09-11-2007, 01:24 PM   #5
dukeduster
Member#: 95789
2002 WRX PTE
yeah well nit did smoke like crazy on a cold startup. once warmed up all was well. I sure detonation had a lot to do wiht it too but the last 3k miles of the motors life was detonation free.
Old 09-11-2007, 01:40 PM   #6
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Sooo, when you say smoke like crazy can you show us a video? Whats the compression at? What are your leak down values?
I remember your tuning posts. How much boost were u running?
NITROS is offline
Old 09-11-2007, 01:53 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Heh, 3k of detonation on a built motor and you expect it to last?
IMO, you need to fix other problems before putting another built motor in there.
8Complex is offline
Old 09-11-2007, 02:01 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
I'm going to say the motor was killed in the initial 3k miles due to detonation...poor rings never had a chance...
what did you do for your break in period?...please be complete and precise with the answer.
Old 09-11-2007, 07:40 PM   #9
modaddict
Member#: 95840
sold to a good bud
awaiting next car
atleast the OP can make a "lol" at his mistakes!
modaddict is offline
Old 09-11-2007, 09:03 PM   #10
jays05
Member#: 78165
05 STI 35r + e85
How could you ever blame the engine?!?
http://forums.nasioc.com/forums/show....php?t=1214410
I have never seen so many knock counts in a datalog.
jays05 is offline
Old 09-11-2007, 09:04 PM   #11
dukeduster
Member#: 95789
2002 WRX PTE
it very well could been killed die to detonation. The problem was is that the inter cooler sucked major balls for the turbo i was running. just got too hot and liked to detonate. I dont have any smokey videos either. either way the ring wasnt set up right anyways. I am not knocking axis motors either! i think they are pretty fair quality. at least the stage 2 is. My motor detonated under light boost since i started tuning it. I dont know why either. I wanted to run 15psi on pump at about 17 degrees timing and it would detonate. i had to back it down to 14 degrees before the detonation went away. I am pretty sure the egts were just too hot and the intercooler had A LOT to do with the destruction of the engine. I am not mad about either you dont hear me blasting on anything just sharing my experience.
Old 09-11-2007, 09:05 PM   #12
dukeduster
Member#: 95789
2002 WRX PTE
I dont remember putting a post blaming the engine for the detonation? I blamed it for not firing on the cylinder that died!
Old 09-11-2007, 09:06 PM   #13
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
were you sure of your gas quality? And did you check your entire setup to ensure that there were no othe probles that were causing you strife in the tuning department?
jigga is offline
Old 09-11-2007, 09:10 PM   #14
dukeduster
Member#: 95789
2002 WRX PTE
i tried a bunch of sifferent gas brands and the only thing that cured detonation is alchohol or race gas
Old 09-11-2007, 09:12 PM   #15
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
what intercooler were you using again??
jigga is offline
Old 09-11-2007, 09:18 PM   #16
dukeduster
Member#: 95789
2002 WRX PTE
ebay top mount
Old 09-11-2007, 09:18 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
I'm still wondering why you are blaming a chamber for not firing...either it was your fuel or fire that was not working...that piston, even with rings in a straight line will make enough compression to fire...
I personally think it was your plug gap/temp range...either that or a short.
Old 09-12-2007, 01:23 AM   #18
modaddict
Member#: 95840
sold to a good bud
awaiting next car
THE best quote in that thread:
Originally Posted by NITROS View Post
Hey do me a favor and post your timing map that way i can see what your doing man.
IF THAT CEL FLASHES. LET OFF IMMEDIATELY DO NOT DRIVE THROUGHT IT. YOUR ENGINE WILL BLOW UP.
Old 09-12-2007, 09:39 AM   #19
dukeduster
Member#: 95789
2002 WRX PTE
sometimes i wonder why i even post here
Old 09-12-2007, 10:19 AM   #20
rewt
Member#: 60794
2007 Solstice GXP
What do you mean a cylinder didn't fire? Were you able to verify the cylinder was not getting spark? I would assume that if you were getting good compression numbers, the rings seated fine.
Also, the detonation you experienced could have been caused by a number of variables, and a few I could suggest just based on the info in this thread include:
1.) Gas quality/octane
2.) Poor intercooling
3.) Tuning
These three variables lead to detonation which killed your motor. Live and learn. So what are your plans now? Rebuild?
rewt is offline
Old 09-12-2007, 11:00 AM   #21
Porkchop-WRX
Member#: 33293
2011 4-door STi
Plasma Blue
Well when you buy a nice short block then go buy a cheezy ebay tmic what do you expect.
Go big or go home.
Porkchop-WRX is offline
Old 09-12-2007, 11:04 AM   #22
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Other people wonder as well. Your original post doesn't really have a point or a question to it.
8Complex is offline
Old 09-12-2007, 09:08 PM   #23
dukeduster
Member#: 95789
2002 WRX PTE
Definitely gonna do a rebuild. This time with a hx40 holset and prolly better rods and pistons on a ej257. Hell its just a motor. mr complex moderator FYI my post is very informative due to the fact of sharing my experiences of the axis stage 2 motor with what mods and tuning i had. so piss off
Old 09-12-2007, 10:46 PM   #24
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I beg to differ. Your post not only had no question or technical information in it, but your spelling, grammar, punctuation, and thought seperation outright suck.
Perhaps someone will complain about me "getting in the last word and closing the post" but frankly, this post is going nowhere and has nothing to give to the community other then to make sure to get your car professionally tuned.
8Complex is offline
Closed Thread
Upstate NY: 1998 2.5RS-T with Axis stage 2 shortblock and PPGs Keith Private Vehicle 'For Sale' Classifieds 9 10-30-2009 06:22 PM
gauging interest: 1998 2.5RS-t with Axis stage 2 motor (new)... Keith Private Vehicle 'For Sale' Classifieds 28 02-18-2009 02:40 PM
Keith's, "I can't get my car inspected" sale. RS-t with Axis stage 2 STi block Keith NESIC Private Classifieds 31 03-22-2008 07:33 PM
2.5 Axis Stage 2 bottom end.... any good?? frayz Built Motor Discussion 6 08-23-2007 03:38 PM
Axis Stage 2 vs. USDM STi 2.5 Chad W Built Motor Discussion 14 04-29-2007 11:40 PM
