Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 09-11-2007, 12:13 PM   #1
dubya-R-ex
Member#: 113698
Default Recommendation needed: 2.5 or 2.0 WRX heads better for engine build? (NON-AVCS)
I am in the midst of doing an engine build with an STi short-block to go into my WRX. I intend on running non-AVCS. Which is the better choice of heads? 2.5L or 2.0L WRX heads? I plan on porting and building the heads and pretty much going all out with the APS tumbler deletes, port and polish 20G most likely, perhaps a 30R. Just curious which provides the better platform for an engine build and which provides the most potential. Please speak with experience if you are going to respond. Thanks!
dubya-R-ex is offline   Reply With Quote
Old 09-11-2007, 02:13 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
dont forget about 2.0l sti heads (v7/8), i dont think they are too expensive if compared to the 2.5l sti heads so consider those as well.
i only have a 2.0l so i cant really comment on these heads on a 2.5l since i dont have first hand experience just wanted to throw another option at you
PaulRex is offline   Reply With Quote
Old 09-11-2007, 03:22 PM   #3
Freon
Member#: 88322
2009 BMW 135i
You really should get AVCS working if at all possible.
Freon is offline   Reply With Quote
Old 09-11-2007, 03:53 PM   #4
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
very expensive to run AVCS.
If you can get 2.5L heads, go with those. If you don't have enough $$$ then the least you should do is upgrade the cams.
I am running an STi shorty with my 2.0L wrx heads. I have great torque but power falls off a little past 5k rpm. With upgraded cams, you should be able to have good power through out the power band.
just my .02
MindzeyeWRX02 is offline   Reply With Quote
Old 09-11-2007, 06:16 PM   #5
dubya-R-ex
Member#: 113698
just my .02
This is the type of response that I was looking for! Not some crap about recommending JDM heads. I don't intend on changing the ECU.
Upgraded cams and port/polish are planned. I am just wondering what the better base is for these upgrades. Simple enough I thought.
Old 09-11-2007, 07:12 PM   #6
Texy32
Member#: 124252
0506 STI/Tribeca
OBP/SGM
Default heads
Wrx's heads can flow just as well with porting and polishing. I second the cam upgrade. i had a hybrid 2.5/ 2.0 heads. it does flatten out unless you PnP the heads and upgrade the cams. There is someone on here now sell wrx race cams for $400. which is a steal. Make sure you run a line from the extra oil vent on the top of the 2.5 block to one of the heads.
Texy32 is offline   Reply With Quote
Old 09-12-2007, 01:36 AM   #7
bakka
Member#: 112072
2004 wrx
blue
I have a built 2.5 bottom, p/p wrx heads, valves, springs and retainers with crower stage 3 cams.The car made 469 whp on pump gas. High compression makes it pull very hard.
bakka is offline   Reply With Quote
Old 09-12-2007, 01:39 AM   #8
motoryder
Member#: 111268
.... MLTMFA2
Turbo?
The one thing I wish I could've done over for my engine was to throw on a set of cams...
motoryder is offline   Reply With Quote
Old 09-12-2007, 02:29 AM   #9
wrxdaddy
Member#: 14164
02 Impreza Wgn
95 L Project in progress
.... High compression makes it pull very hard.
What is your compression numbers? 8.7:1 or higher?
wrxdaddy is offline   Reply With Quote
Old 09-12-2007, 12:54 PM   #10
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Bakka has standard STI head gaskets and 2.0 built WRX heads. Turbo is a FP 3065. The car hauls major ass
Junior2JZ is offline   Reply With Quote
Old 09-13-2007, 09:52 PM   #11
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
USDM WRX (2.0) and USDM STi have identical ports but the STi has a slightly larger combustion chamber. It's very easy to have the chamber enlarged on the 2.0 heads to keep compression down and still use the proper sized head gasket (piston to head clearance should never exceed 1.2mm) if that's what you're interested in. Keep in mind the higher CR will help retain low end torque with the ported heads and larger cams - and spool a turbo faster.
PeteDucati is offline   Reply With Quote
Old 03-28-2011, 08:56 AM   #12
akaerik21
Member#: 277865
sanded down
what kind of hp can I expect to get from a non built sti SB and wrx heads with the chamber enlarged to match the sti heads, running all stock internals?
akaerik21 is offline   Reply With Quote
Old 03-29-2011, 03:02 PM   #13
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
The S20 heads will give you the most flexibility to port for your application. They are small port to start with but have enough meat to enlarge to the same size as JDM big port heads.
I went huge on mines:
-soobaviator
soobaviator is offline   Reply With Quote
Old 03-29-2011, 04:01 PM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
hp is on your turbo choice and fuel.
expect it to be like an STi head running on stock wrx cams, less lift.
FuJi K is offline   Reply With Quote
Old 03-29-2011, 04:29 PM   #15
OrbitalEllipses
Member#: 178811
2013 WRB BRZ Limited
For Sale!
You'll want to at least pick up STI cams and plug them if not upgrade to something like a Kelford 264 or bigger.
OrbitalEllipses is offline   Reply With Quote
Old 03-29-2011, 09:17 PM   #16
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
I have a set of ported B25 heads that have been modified for non avcs. Plugged sti cams, wrx cam sensor mounted, you'll need new seals. Too lazy to rewire the hydra in my '95 so I'm going to run the phase 1 dohc heads that are in it on a ej257. PM me if interested.
theotherguy is offline   Reply With Quote
wtb:fp green or blouch dom 2.5 or 3.0 Derek C NESIC Private Classifieds 0 04-01-2009 04:47 PM
WTB: 2.5 or 2.0 wrx heads. mvcsk8r NESIC Private Classifieds 0 03-12-2009 11:41 AM
Wtb Short Block 2.5 Or 2.0 twrxmess Private 'Wanted' Classifieds 6 02-09-2009 02:37 AM
help! which knock sensor 2.5 or 2.0? WRB04 Service & Maintenance 2 10-30-2007 02:20 PM
2.5 or 2.0 DausWRX Built Motor Discussion 10 09-06-2007 09:48 AM
