Old 09-11-2007, 04:55 PM   #1
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
Default Element GT52.
the car made 401whp/380wtq on 93 octane and between 19-20psi. i haven't had the Hydramist tuned yet. it was tuned by Corey Parrish at SlowMotionMotorsports in Columbus,Ohio.
Dyno=Dynapack.
-new 257 block with overbore for 100mm pistons
-100mm wiseco pistons (originally ordered 100mm mahle but found out after build that they used wiseco)
-manley rods
-arp studs
-crower stage II cams
-stock heads with new subaru valves
-power enterprise timing belt
-fuel pressure regulator with gage on it.
-hydra
-hydramist
-gt52 bolt-on
-tail 44mm to street (mounted on vishnu uppipe)
previous engine mods (*=no longer on car):
-stock 2.0*
-stock heads
-fp18g internally gated*
-utec*
-greddy profec b spec II
-tgv delets
-perrin inlet and intake
-perrin fuel rails
-pe800's
-walbro
-txs front mount
-vishnu pulley
-vishnu catless tbe "signature series"(most overpriced pipe ever)
-Vibrant Ultra Quiet Resonator.(i really love this thing.)
drivetrain:
-jdm 6-speed non-dccd
-version 7 r180 with 2-pots
-exedy twin disc
-DSS alluminum shaft
-DSS front axles
(somebody usually asks this one)
Comments are welcome.
kharris4 is offline   Reply With Quote
Old 09-11-2007, 05:50 PM   #2
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
nice.
u can go with more boost right?
does it seem somewhat laggy?
stickman is offline   Reply With Quote
Old 09-11-2007, 06:07 PM   #3
redrex2002
Member#: 118915
2002 wrx
srp
when do you see full bost, and also do you think that this turbo would benefit from some minor hear work, also a mild cam upgrade. or possibly have different chacteristics with the jdm v8 heads?
redrex2002 is offline   Reply With Quote
Old 09-11-2007, 06:13 PM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
i would think that with V8 heads, he might get slower spool up due to the larger ports and slower velocity compared to the stock heads. More top end power though likely.
Most cams on the market move the powerband to the right with a loss at the left side, so I imagine again, slower spool, and more top end power.
jigga is offline   Reply With Quote
Old 09-11-2007, 06:20 PM   #5
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
But with a 2.5L that might rev to 7500RPMs and a large turbo that will probably hold out plenty long do you really need help moving the power band to the right? I figure something like that might be nice for a high-revving 207. I've been wondering about this.
djoye is offline   Reply With Quote
Old 09-11-2007, 06:35 PM   #6
lethal.adv
Member#: 95652
'12 Outback 2.5i
'10 Legacy 2.5i ltd.
vids please
lethal.adv is offline   Reply With Quote
Old 09-11-2007, 06:43 PM   #7
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
^^ Plz!
Fast_Wrx62 is offline   Reply With Quote
Old 09-11-2007, 07:19 PM   #8
kharris4
Member#: 46018
2003 wrx
did you guys see that it has Crower Stg II cams?
i was only looking for an easy 400whp on pump gas. even more when i tune in the Hydramist. i know what other cars are like that were tuned on this dyno, so i know where 400whp should put me.
boost seems to come on fast in all gears(jdm 6-speed).
i may upgrade the heads in the future, but for now i'd like to just get the Hydramist tuned and enjoy what i have.
Old 09-11-2007, 09:55 PM   #9
a04subaruwrxSTi
Member#: 129787
04 STI
Java Black Pearl
subarus are making more and more crazy HP gains! I love it!
a04subaruwrxSTi is offline   Reply With Quote
Old 09-11-2007, 10:15 PM   #10
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
It looks like the cams really help keep the torque up top. I've got the same ones, but with a 20G.
McBain_TP is offline   Reply With Quote
Old 09-12-2007, 09:20 AM   #11
ejh25
Member#: 65267
I have a similar setup:
Built block w/ V8 heads and cams with some valvetrain upgrades and a GT52.
You should gain almost 40 whp with the Hydramist.
I did 500/507 with hydramist and 110 leaded.
The GT52 rocks!
ejh25 is offline   Reply With Quote
Old 09-12-2007, 10:03 AM   #12
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
I also have a similar set-up
+1 for the GT52
more Info here on me and my turbo here:
http://forums.nasioc.com/forums/show....php?t=1111597
Engine Control:
Element Hydra Nemesis Engine management system
Wid ban 02
Launch Control
Motor:
CP Custom Spec Forged Race Pistons OEM Bore w/rings 9.5:1 compression
Proto-type Element tuning rods
Cosworth camshafts 278/274
Cosworth Valves/spring/retainers
ARP Head studs
Element competition catch can
NGK 1 step colder spark plugs
Drivetrain:
Clutchmaster Stage 4 clutch
Turbo:
Element GT52 Turbocharger
Intake:
K&N Cone Filter
Perrin Short ram
Samco Turbo Inlet
Exhaust:
Greddy Headers
Element FEW Competition EWG up-pipe
Tial 38mm Waste gate
Turbo XS custom 4” Down Pipe
Turbo XS 3” RFL Ti exhaust
Fuel delivery:
Perrin 816cc Injectors
Walbro Fuel pump
JDM TGV deletes
Hydramist Methanol Injection Kit
Cooling:
Turbo XS Front Mount Intercooler & piping
Turbosmart Raceport Blow Off Valve
Zerosports Thermostat
Koyo Radiator
GT Spec Radiator shroud
THE-95-STi is offline   Reply With Quote
Old 09-12-2007, 10:10 AM   #13
jgheels2003
Member#: 64562
2012 Boss 302
Very impressive!
jgheels2003 is offline   Reply With Quote
Old 09-12-2007, 11:53 AM   #14
kharris4
Member#: 46018
2003 wrx
It might not be the fastest car on the streets, but it did start to bust the tires(yokohama es100 235/40/17) loose getting on the freeway earlier today.
two questions:
-what type of water mixture are you GT52/Hydramist owners running?
-who makes a decent knock lite that is affordable?
also, i may just build a RWD version of this with an older/lighter suby.
Old 09-12-2007, 12:41 PM   #15
ejh25
Member#: 65267
two questions:
Windshield washer fluid the -20c kind....
I believe TXS makes a knock lite...
Old 09-12-2007, 01:02 PM   #16
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
^^^+1
The blue stuff that costs like .99
Old 09-12-2007, 01:03 PM   #17
namitherussian
Member#: 69489
MBP, F250
what did your previous set up make?
namitherussian is offline   Reply With Quote
Old 09-12-2007, 01:15 PM   #18
kharris4
Member#: 46018
2003 wrx
18g on 2.0 made about 290whp/270wtq at Godspeed. a while back.
Old 09-12-2007, 01:15 PM   #19
kharris4
Member#: 46018
2003 wrx
also, no injection with that 18g.
Old 09-13-2007, 04:33 PM   #20
2004stiwrb
Member#: 70613
i'm @ the dragstrip
with over 600awhp!!!!!!!!
congrats on the numbers, corey is very good at what he does but jon schroeck had a hand in this tune also.
2004stiwrb is offline   Reply With Quote
Old 09-13-2007, 05:27 PM   #21
rexhio
Member#: 97834
nice. slowmo does good tuning
rexhio is offline   Reply With Quote
Old 09-13-2007, 09:17 PM   #22
kharris4
Member#: 46018
2003 wrx
i wasn't actually there when they were tuning it. how do you know that Jon was there? now i feel bad for not mentioning him in my original post.
the car seems to be running pretty well. i'll be going back to have the Hydramist tuned and maybe even a race gas map.
Old 09-13-2007, 10:18 PM   #23
2004stiwrb
Member#: 70613
i'm @ the dragstrip
he is one of my best friends thats how i knew. you should def. get it back in for racegas and water injection.
Old 09-13-2007, 10:53 PM   #24
keaniegenie
Member#: 94494
2005 Element 92x
I also have a similar setup.
Stock EJ257 longblock
aps 3" tbe
aps header
txs intake
txs ic
hydra
hydramist
perrin inlet
modded injectors
walbro
I'll be putting a fmic with reversed manifold next.
Water injection will make a huge difference! You'll see.
keaniegenie is offline   Reply With Quote
Old 09-14-2007, 08:17 AM   #25
kharris4
Member#: 46018
2003 wrx
2004stiwrb- if you talk to Jon, please give him my thanks.
Element Gt52 tuning notes - great unit Dyno Flash Proven Power Bragging 97 06-07-2007 06:03 PM
Element GT52 Turbo/Hydra/Hydramist 436 whp Element Tuning Proven Power Bragging 60 10-25-2006 11:05 PM
AZ: Element GT52 Turbo, TXS FMIC, Tial 38mm WG hulkmanj99 Engine/Power/Exhaust 5 10-24-2006 09:40 PM
Element GT52 Bolt-on Turbocharger WTillIDIE Proven Power Bragging 11 10-23-2006 01:39 PM
element gt52 redrex2002 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 70 10-19-2006 03:07 PM
