Old 08-16-2002, 11:41 AM   #76
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default hey now
The 2000+s look good too(except for the bulging wagon roofline.)
But lets not forget Morettes et. al. are not just about looks. They are about POWER too babee. Producing light that can strip the flesh from your very bones!!!! muhahahahaaaa
You did kinda pass on that whole better light thing there 2001LegactGT.
subysouth
subysouth is offline   Reply With Quote
Old 08-16-2002, 05:46 PM   #77
2001LegactGT
Member#: 5089
2002 Audi A4
Denim Blue
I guess light doesn't impress me that much
I've never noticed a problem with mine
2001LegactGT is offline   Reply With Quote
Old 08-16-2002, 06:58 PM   #78
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Maybe the MY00+ headlights are OK. The factory lights on my "old" MY97 SUCKED? I love driving fast at night and the morretes make it much safer. Gives me a chance to slow down for the deer.
HIHO is offline   Reply With Quote
Old 08-16-2002, 07:19 PM   #79
LGYGT
Member#: 11380
1997 Legacy GT
Hey HIHO,
your lights are awesome and I like it very much, very did you get it and does it comes with everything like light bulbs and instruction?
How hard is it to put it on and did you take pics step by step while you installing?
Please let me know.
Jay
MY97GT
LGYGT is offline   Reply With Quote
Old 08-16-2002, 07:20 PM   #80
Schludwiller
Member#: 22066
1999 BD-GT 30Yr Std
Yes, the '97's were really bad. Looking at my '99's it appears they modified the reflector but I don't have my '97 around to compare any more. I bought my Morettes for my '97, but it was totalled before I could get them in. Good thing the '99 still has the same assembly.
Schludwiller is offline   Reply With Quote
Old 08-17-2002, 08:43 AM   #81
HIHO
Member#: 7624
BD5; family sedan
Originally posted by LGYGT
Hey HIHO,
Please let me know.
Jay
MY97GT
Thanks.
I bought them from Adam at Z1 Performance. Yes it comes with everything. The instructions suck but the install was easy to figure out. They are very easy to install you only have to splice 2-3 wires. I didn't take any pics of the install, but I am sure that most people can figure it out.
Good luck and email me if you have any questions.
Old 01-19-2003, 05:29 PM   #82
Schludwiller
Member#: 22066
1999 BD-GT 30Yr Std
Default Wiring help
Well dammit!
I figured I could get my Morettes installed in about an hour and catch the playoffs. I have the old style without the plug, so we tried to figure out the wiring. We finally got the high beam and low beam's switching but here's the problem.
The switch inside the vehicle compartment is reversed! So my high beam selection turns on the low beams and the low beams turn on the high beams.
You would think that all you had to do is switch the wires on the headlights, but that doesn't work. We're completely confused and have given up for the weekend. I'm going to try and order the plug harness that is available now, but does anyone have an alternate suggestion.
Oh, and did I mention that the vertical adjustment bolt is missing from the lights? I hadn't noticed until working on the lights today. I could jerry-rig something, but hopefully I can get this ordered as well. I just hope my car isn't sitting in my garage forever.
Old 01-19-2003, 05:57 PM   #83
etam
Member#: 439
www
Subaru uses ground switch system for headlights.
etam is offline   Reply With Quote
Old 01-19-2003, 06:13 PM   #84
Schludwiller
Member#: 22066
1999 BD-GT 30Yr Std
Ok, that's helpful. The Morettes came with a ground line that we attached to a frame ground and we didn't use the plug-ground (the end of the morette ground had the round attachment for a screw ground so we used that, instead of going in-line to the plug wires we cut)
So maybe the stock ground goes to the Morette relay? I'm trying to understand how to make the transfer from a single headlight system with a switched ground to a dual headlight system. I'm still having a conceptual problem with how a ground switch with one line performs. I'll do some searches on this.
Any more insights?
Old 01-20-2003, 12:27 AM   #85
etam
Member#: 439
www
I don't know about morette but this is how I wired my JDM projector headlights:
stock H4 connections (looking at the bottom of the bulb):
wirings for JDM projector headlights (common ground):
Old 01-20-2003, 01:23 AM   #86
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
so what would be better?
1. morretes?
2. jdm projectors?
3. 99 leg head lights, with a hid kit?
and on that hid kit, can you get some that will have a high beam? or do you have to buy a set of like projector hids that mount some other place? like a set of fog lights.
subiekid is offline   Reply With Quote
Old 01-20-2003, 09:58 PM   #87
Schludwiller
Member#: 22066
1999 BD-GT 30Yr Std
Well I'm getting the aftermarket plugs, so that should help with the wiring issue. I still have the missing vertical adjustment screw for the low-beam projectors. I don't know if it's possible, but can any of you Morette owners take a picture of what should be in the open spot on my lights (pic below)? Thanks.
Old 01-20-2003, 10:02 PM   #88
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Default Material
What is the frame made of? Is it the same for the surround that is visible from the front of the car?
What do you think of the construction? I really want to do this, but am broke for now. Thanks in advance.
Old 01-21-2003, 11:19 AM   #89
Schludwiller
Member#: 22066
1999 BD-GT 30Yr Std
Default Re: Material
The frame is mostly plastic with some metal but certainly as strong as the OEM light. The front is a separate piece that is removable and paintable. The light construction is very solid. I'll let you know how they perform at night once I get this wiring problem fixed.
Old 01-21-2003, 11:31 AM   #90
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
schludwiller, did you buy the Morrettes used? Is that why the hardware is missing or did Morrette send them out without it?
g/l on your install. I have not checked the bulbs in my car directly but based upon beam pattern it looks like the two filaments do not operate simultaneously. Do the Morrettes operate both bulbs in hi-beam mode?
ss
Old 01-21-2003, 05:44 PM   #91
HIHO
Member#: 7624
BD5; family sedan
Yes BOTH are on with highbeams. I didn't have any trouble with mine. Maybe the MY97 and MY99 are diferent(factory harness). I will try to take a picture of mine tomorrow but I have no way to post them.
FS : PRICE DROP 5x100 18x8 Rota Tarmac III's In Gold w/ Toyo Proxies jbark1018 Wheels/Tires 9 06-02-2010 09:27 PM
blue wrx with morrets @ De Anza blvd 4wdori Bay Area Impreza Club Forum -- BAIC 0 01-25-2002 07:11 PM
My GT with new Morrets and Hella FF100. HIHO Member's Car Gallery 4 01-20-2002 05:50 PM
If you have Morretes (or getting some) check this out! HIHO Legacy Forum 11 01-12-2002 04:57 PM
<-- Eligible Bachelor in NJ nkodemus82 Tri-State Area Forum 14 06-26-2001 11:20 PM
