Old 09-11-2007, 09:24 PM   #1
whipito
Member#: 134310
2005 Impreza2.5 RS-T
BLACK
Arrow Sti Pistons Rods Rings
Does the STI PISTONS RODS and RINGS fit on a 2005 2.5rs engine?
If not what should be changed?
whipito is offline   Reply With Quote
Old 09-11-2007, 10:11 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
yes. keep in mid the sti pistons have alot more piston dish than the 2005 rs pistons.
~Josh~
Old 09-12-2007, 01:59 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Yes, but its the crank that counts.....
If the crank is 75 mm throw, and the rods and pistons are set up for 79mm throw, then youl will be 4 mm short of the ideal quench.
Old 09-12-2007, 02:20 AM   #4
subie4me
Member#: 89218
He said 2.5 rs. I thought that had a 79mm stroke crank.
OOPS, I forgot, the sti uses 52mm rod journals. The 2.5 rs is a phase one motor. It has 48's. No, it will not work.
subie4me is offline   Reply With Quote
Old 09-12-2007, 04:46 AM   #5
Brydon
Member#: 107569
1998 Forester S
SRP
Um no. The RS uses the STI crank from 99+ ... You will be fine.
Brydon is offline   Reply With Quote
Old 09-13-2007, 10:31 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
like i said.....they will fit, being a phase 2 ej25, it uses the 52mm bearings.
~Josh~
Old 09-15-2007, 01:10 AM   #7
whipito
Member#: 134310
BLACK
Question Thanks everyone!
Would I need to change something else or upgrade since engine will be opened? Or is it better installing them and then try to find an STI engine in future?
Old 09-15-2007, 01:11 AM   #8
whipito
Member#: 134310
BLACK
Question
How can I know if it's phase 2?
FS: (PA) Brand new set of STi Pistons, pins, rings, Connecting rods BlueHeavenWRX Engine/Power/Exhaust 32 12-25-2008 10:13 PM
Sti Pistons, ROds, & Rings NvrEnuff MAIC Private Classifieds 2 04-23-2007 11:07 AM
FS: New 04 STi Pistons w/rings Autopilot747 Engine/Power/Exhaust 19 11-05-2006 06:59 AM
sti piston oil ring assembly?? Pi7467mp Built Motor Discussion 8 04-28-2006 03:19 PM
Pistons, rods, rings and bearings! boostinscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-04-2005 12:46 AM
