Welcome to the North American Subaru Impreza Owners Club Wednesday July 23, 2014
Old 09-12-2007, 08:30 AM   #1
greysave
Member#: 62395
2005 STI
Default Defi illumination problem
I followed D Tech's instructions and I am having a simple problem with the gauges. When I turn the car on the illuminate for the initial sweep then stay dark. When I turn the headlights on they also illuminate. How do I get them to illuminate when the lights are off?
greysave is offline   Reply With Quote
Old 09-18-2007, 04:53 PM   #2
armyssoldierboy
Member#: 109424
06 AW STI
TS HTA 3076r 436hp/426tq
+1 I have the same problem. I want my defi's to dim with the cluster. Someone once told me to hook up the illumin. wire to the power wire of the hazard switch cuz it dims with the dimmer swith. They told me that basically the reason why the hvac and the hazard switch dim is because the dimmer switch is lowering the ammount of power going to those areas... hence the dimming. Anyone heard of this method?
armyssoldierboy is offline   Reply With Quote
Old 09-18-2007, 09:24 PM   #3
olympus
Member#: 74637
Which Defi gauges do you have? I assume the BFs. Check where the gauges are plugged into on the control unit. I believe the BFs should be plugged into output #2.
olympus is offline   Reply With Quote
Old 09-19-2007, 02:55 AM   #4
OKR S06
Member#: 116105
2001 Civic/2006 WRX
Blue/Steel Grey Metallic
That is correct. If you have it plugged into the wrong output it will not light up. One connection is for the Link series (i.e. WRX green) and the other is for the BF series (i.e. STi)
OKR S06 is offline   Reply With Quote
Old 09-19-2007, 03:38 PM   #5
armyssoldierboy
Member#: 109424
06 AW STI
ok, now since thats the case, what if i were to have 3 bf's in the center pod and another 2 to go in the a-pillar. i just ordered another wire to hook those up....wait, i might have just answered my own question due to the daisy chain. but still how would you recommend running the wire from the a-pillar to the center pod?? between the dash and the windshield?
Old 11-20-2007, 11:02 AM   #6
greysave
Member#: 62395
2005 STI
Can you daisy chain the gauges together and plug just one into the control unit?
Old 11-20-2007, 11:22 AM   #7
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 12.8@105mph
you can use the dimmer switch on the radio harness..i am not sure off the top of my head which color it is but that would dim with lights like you want.
boostdog is offline   Reply With Quote
Old 11-20-2007, 08:27 PM   #8
SimonJ
Member#: 135309
Make sure they're in Output 2.
Daisy chain them all together and have 1 wire to the control unit
SimonJ is online now   Reply With Quote
06 factory boost gauge illumination problem Psybin Interior & Exterior Modification 2 12-06-2006 08:51 AM
Dash/Climate Control/Radio display illumination problem!! TyR1 Electrical & Lighting 16 07-27-2006 12:32 PM
Defi Illumination Wire Tap (Control Unit) Trunk_Monkey Electrical & Lighting 2 02-21-2006 05:35 PM
Dash illumination problem bbrewer Service & Maintenance 0 01-30-2002 03:46 PM
