Old 09-12-2007, 11:09 AM   #1
caterpill
Member#: 27136
Default A/C Compressor Oil - Unable to find correct type "Zexel Type R" ??
I've been trying to find out what kind of A/C compressor oil my 1994 Impreza Wagon takes. I am ready to swap out the leaky discharge hose, but I need to find out what kind of oil I need. It's R-134a, so I know it's PAG oil, and the service manual states that it's a Zexel Rotary Vane compressor, so I know that the oil also needs to be pretty thick. Unfortunately, the service manual states , use "Zexel Type R Oil", which doesn't help me in any way in finding an aftermarket.
I searched and only found another thread with a 96' Legacy, and his compressor had "Zexel 200" on it, or something to that extent. It was concluded that it was probably PAG 200 for that system.
Does anyone know what I should use? The compressor is a slightly noisy but I believe it's a bit low on oil.. I bought it used with 80k miles and it seems that the A/C hasn't been serviced since. It works fine besides the leak.
Thank You In Advance.
caterpill is offline   Reply With Quote
Old 09-12-2007, 01:45 PM   #2
avk
Member#: 17252
'06 WX8
59E
Does your compressor still have a specification label, or is it gone?
It should be a Calsonic CR-14, which is probably the same as Zexel
rotary vane, but different from the Legacy unit.
I believe it takes a 100 viscosity oil.
avk is offline   Reply With Quote
Old 09-12-2007, 11:43 PM   #3
caterpill
Member#: 27136
I still have to check if there is a label.
Hm.. PAG 100 huh?
I know rotary vane types favor thicker oils, but yeah, I have to check the label. If I can't find it, I might try PAG 150.
I'll try taking a look at it tomorrow.
Thanks.
Old 09-23-2007, 03:33 AM   #4
caterpill
Member#: 27136
Whoops, forgot to update the thread. I didn't get to check out the compressor label, but found a quick reference guidebook from Four Seasons that included system oil capacities / refrigerant capacities.
You were right! PAG 100 it was. Thank you for your help.
The compressor, ehh, didn't really get any quieter but it is cheap insurance to add a bit of oil. The clutch still squeaks on engagement but airgap and current to the coil is fine. Shrug. As long as it works.
Need to find correct gear for my car 06 Wagon 6speed STIWAGON06 Transmission (AT/MT) & Driveline 11 06-05-2010 11:37 AM
WAPCE that made Domino's gross-out video unable to find work... Wagon Of Fury Off-Topic 16 05-06-2009 02:59 PM
Have you ever been unable to find a song no matter what? pio!pio! Off-Topic 29 06-29-2007 06:42 AM
Unable to find API Sevice SL oil. njchen24 General Community 6 11-16-2005 11:12 PM
Where to turn when I am unable to find affordable auto insurance in NJ? munkis Tri-State Area Forum 36 01-21-2003 09:15 PM
